Grading Rotating rear blade questions
   / Rotating rear blade questions #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I read a review the other day of the TSC Countryline rear blade and got to wondering...
Do most mfg make the rear blade so you can rotate it without unhooking? I assumed - and you know where that gets you - that all rear blades could be rotated 360 degrees without having to unhook them..
I wasnt sure how to even search for this topic - sorry if it has been covered before
Brian
   / Rotating rear blade questions #2
Most will rotate, but it depends on your tractor and the length of the blade.
Usually, if you lift it just above the ground, it will clear the tires.
I can rotate a 7 ft blade on my MF 175
   / Rotating rear blade questions #3
I have a BX2350 with a 5' blade and I can rotate it all the way around. I never thought about it much, but I suppose if it was longer, it wouldn't clear. I would say they are all designed to be rotated without unhooking it, but if I put something like a 7' blade on my tractor, I'm sure it would hit.
   / Rotating rear blade questions #4
For a data point:
My 6' rear blade rotates OK, my 7' landscape rake hits the tires. On a Kubota7800
   / Rotating rear blade questions #5
IMHO, any rear blade should be designed to miss the tractor/tires when rotated. That is just part of a good design. I wouldn't buy one that could not swing in a complete arc. That is why wider blades sit back farther that narrow ones. I frequently swing my blade around for back blading and smoothing or if pushing snow backwards.
   / Rotating rear blade questions #6
The length you have your top link set at can also make a difference.
thanks for the feedback.. The review I read said that the blade would not rotate - and it looks like the exception - OR the reviewer didnt have it in the right position to rotate.
I thought they should, but was just curious
brian
Portable Cattle Loading Shute (A50515)
Portable Cattle...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2012 Cadillac SRX SUV (A50324)
2012 Cadillac SRX...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
2016 Ford Explorer...
