Rotating HD Tree shear/puller ~ Got one?
/ Rotating HD Tree shear/puller ~ Got one?
None taken. My use will be to shear the trees, after they are pushed over or lifted out, depending on the tree, it's root system, and the condition of the terrain. Shallow rooted trees in densely crowded areas near streams are not too difficult to push over, at least not with my Kioti KL-401 loader, capable of lifting 2750+#s. Some bigger trees I will not try to lift, or will shear just below grade and possibly dig out the remaining stump/rootball later with my backhoe with 'claw'/ripper tooth and thumb.
One way or another everything I want gone will be.:thumbsup:
/ Rotating HD Tree shear/puller ~ Got one? #22
Already changed your signature! Lol.
No moss under this rock!:thumbsup:
UPDATE!
Tree Shear arrived yesterday. YEAH. It was on a wood pallet and framed with metal angle iron to form a cage. It was on it's back with the QA and protection grid on the pallet and the shear facing upward. It was well secured to the frame and the frame corners were bolted together and the frame was wired to the shear to keep it together.
All, in all, an impressive way to contain it from damage.
I greased all the pins, YES there are zerks at all crucial points where they need to be. The 5" cylinder is MASSIVE, as is the entire unit. I installed my two male end connectors onto the 3/4" hydraulic hoses, and routed them through the wire grid above the QA plate. This is going to take further though so I don't end up doing damage to the hoses or end connectors on my torque tube of my loader. The hoses are probably long enough, BUT I have to take into account full range of the entire shear in curl and extend, as well as the ability for the hoses to follow the 'swing' from horizontal to vertical without any pinch points or strain on fittings / hoses.
The shear works great, BUT one wants to make absolutely sure it is locked into the QA before moving the tractor - obviously; but it bears mentioning due to it's weight of nearly 1000#s!
Once secured and greased, and some Fluid Film or dry graphite sprayed on the shear blade to enhance smooth cuts, away one goes; taking into consideration that there is a serious need for ballast to be used when the shear is on the loader arms. I happen to have my 700# Woods 6' Brush hog on currently. It's adequate but not enough to be completely safe, especially if turning quickly, etc.
The shear opens and closes somewhat slowly compared to say my grapple jaws or my snowplow swing side to side etc., BUT this is a good thing from the standpoint of learning curve with a new piece of equipment.
Higher RPMs will render the close/open speed somewhat higher, but maximum capability would be better on an actual skidsteer, I imagine, due to their higher pump output.
I can't say yet what the maximum tree diameter that could be cut would be, even though the specks call for 12". I have worked my way up to about 1/2 that so far as I get accustomed to the operation of the shear and gain skill at using it. I will say it does whatever I ask of it so far.
One notable drawback is there is no available manual for the shear - Titan says they are working on one. I sure hope so. This is a potentially deadly piece of equipment; and not having instructions on use/maintenance is totally nuts in my opinion. I can say that there are other shear manuals I've looked at online; and this is a good way to familiarise oneself with the basics of operation/safety, etc.
More later.
Thanks,
CM
UPDATE!
I greased all the pins, YES there are zerks at all crucial points where they need to be. The 5" cylinder is MASSIVE, as is the entire unit. I installed my two male end connectors onto the 3/4" hydraulic hoses, and routed them through the wire grid above the QA plate. This is going to take further thought so I don't end up doing damage to the hoses or end connectors on the torque tube of my loader. The hoses are probably long enough, BUT I have to take into account full range of the entire shear in curl and extend, as well as the ability for the hoses to follow the 'swing' from horizontal to vertical, without any pinch points or strain on fittings / hoses.
Once secured and greased, and some Fluid Film or dry graphite sprayed on the shear blade to enhance smooth cuts, away one goes; taking into consideration that there is a serious need for ballast to be used when the shear is on the loader arms. I happen to have my 700# Woods 6' Brush hog on currently. It's adequate, but not enough to be completely safe, especially if turning quickly, etc.
The shear opens and closes somewhat slowly compared to say my grapple jaws or my snow plow swing side to side etc., BUT this is a good thing from the standpoint of learning curve with a new piece of equipment.
I can't say yet what the maximum tree diameter that could be cut would be, even though the specs call for 12". I have worked my way up to about 1/2 that so far as I get accustomed to the operation of the shear and gain skill at using it. I will say it does whatever I ask of it so far.
More later.
Thanks,
CM
/ Rotating HD Tree shear/puller ~ Got one? #26
No pics? Then it doesn't exist!
No video? Then it doesn't operate!
/ Rotating HD Tree shear/puller ~ Got one? #27
:D Yeah We want pics That looks like a really cool piece of equipment.
Will be really really impressed if it can actually cut a 12 inch diameter tree in 2 and then drop it.?
12" sounds like a lot did i misunderstand the 12" part?
Anyway
The uses for our tractors and FELs with mods keep growing with help from users who push the envelope :thumbsup:
/ Rotating HD Tree shear/puller ~ Got one? #28
Heck with Pics - I vote for video!
Sounds really cool
Anyway
Yes, 12" or 1 foot in diameter! I just finished this afternoon on a 9" ash. Dropped it like a hot tamale.:cool2:
Pics when I can get the time to offload/upload.
I'd like to do some video, but I've never uploaded video. I can use a Go=Pro cam I have or a Panasonic Vid cam or my phone. I don't really know what might be best. The first two options contain SD cards, well so does my phone- though it's micro SD.
Any thoughts on what I might want to use for ease of final transfer/uploading to TBN?
Thanks for anyone's input on this ....
CM
/ Rotating HD Tree shear/puller ~ Got one? #31
The only thing Ive ever done was uploading video from my phone to YouTube and then copy-and-paste the YouTube link into my post.
/ Rotating HD Tree shear/puller ~ Got one? #32
This is probably the easiest way to do it.
A GoPro works great and everything goes fairly smooth with YouTube since they are pretty much a "standard".
You certainly can use your phone however if you find it easier.
Thanks and let us know if you need some assistance.
/ Rotating HD Tree shear/puller ~ Got one? #33
UPDATE!
More later.
Thanks,
CM
Just wanted to say Thank You for your business!!! If there's anything you need, let us know. I would love to see some video as well. A youtube link would be great!
Thanks again!!! :thumbsup:
You're welcome. And yes I want to do some sort of video of the shear, soon as I can get to it.
I would like to know when you anticipate having an owner's manual for the shear? It is a top priority from my standpoint.
Thanks,
CM
We can email a PDF copy if that works for you.
That would get me going- but I would like a hard copy for my files on my equipment.:thumbsup:
I'll PM you my email address- which you should already have from the sale- but I'll do it anyway.
Thanks,
CM
Lot 602 (A62613)
Lot 602 (A62613)
More info coming soon (A64557)
More info coming...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2019 Kubota RTV-X900 4x4 Diesel Utility Cart (A66734)
2019 Kubota...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
