Rotating grapple
   / Rotating grapple #1
Hoospie
Columbia
John Deere
We are creating a half-acre trellis with about 40 16-foot 4x4s.
Once the holes are dug, we want to be able to use our large John Deere tractor (have forgotten model number) to pick up each pole with a grapple, raise the pole, turn it 90 degrees and place it into a hole.
We are looking for advice on price range, brands and dealers.
Thanks.
   / Rotating grapple #3
Do you have a hook for a chain on your loader bucket? If so you should be able to chain to the 16' 4x4, off center. and when it is picked up it will go vertical. Then use the curl/dump of the bucket to get it plumb enough to lower into the hole.
   / Rotating grapple
Thank for the replies. Looks like we will be using 6x6s, not the 4x4s I mentioned at first.
I've inquired about the price. Thanks. for the help.
Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
Crane Carrier Co...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A53473)
2021 NEW HOLLAND...
2016 Big Tex 18' Equipment Trailer (A52384)
2016 Big Tex 18'...
90004 (A51694)
90004 (A51694)
