California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,588
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Guys, I'm still baffled and I appreciate your advice. I thought this disc would cut much deeper.
I got the disc with the tractor and was told they had been together for many years. I assumed they were matched.
I can run in H3 at 1600 rpm so I'm not near the limit of power or traction. (max 24 hp @ 2400). The disc is mostly rolling along on top and scalping a few inches. I tried a final slow pass and it cut only slightly better.
I'm running total 800 lbs. (680 lbs disc + 120 lbs ballast shown here). When I bought it, I left behind 250 lbs of junk the previous owner had lashed on.
The neighbor I am discing for said his father sharpened his discs each winter. Is that needed, or helpful? Is there some other variable to tinker with, such as shortening the top link to make the nose dig in? (It's level now). Maybe the soil was too dry. This was the day after a rain, but the soil dried quickly as it was turned over.
Actual cutting width is 66 inches. How much should a 66 inch disc weigh? Should I add ballast until I run out of traction?
This is hobby use so I will probably make do with what I have. A rototiller looks nice but I can't justify a new one.
