Rotary Tiller Recommendations for TYM T25 Tractor
   / Rotary Tiller Recommendations for TYM T25 Tractor #1
Bert the Bard
RK25
If you own a 25hp tractor and have any advice on what I should get, I'm all ears. :giggle:
   / Rotary Tiller Recommendations for TYM T25 Tractor #2
Buy a tiller that is rated at a lower PTO HP than the PTO HP that the tractor can deliver.
As an example, if the tractor has a PTO HP of 20, then look for a tiller that is rated for a PTO HP of around 15.
Good luck with your search!
   / Rotary Tiller Recommendations for TYM T25 Tractor #3
4 foot tiller for a 25 hp tractor.
   / Rotary Tiller Recommendations for TYM T25 Tractor #4
I have the 5' King Kutter II tiller for my Kubota L2502 (25HP) and it is a very well made, heavy duty tiller. My 2502 runs it very well, no issues whatsoever.
Mine had been used only twice and I picked it up for $600 off of a buddy.
   / Rotary Tiller Recommendations for TYM T25 Tractor #5
You don't say where you are or the type of ground you want to till. If you're tilling sand, a six footer will work. If you're tilling hard clay, only dynamite will work.
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
