Rotary tiller questions
   / Rotary tiller questions #11
The biggest I've ever heard of is 8 feet wide. That would be a real monster. I'm sure they make bigger but you gotta figure the area you will be tilling and how are you going to navigate around it.
   / Rotary tiller questions #12
I've seen 12' tillers and they come wider than that...
SR
   / Rotary tiller questions #13
Get a 7 footer in an Ag rated brand that the blueberry farmers use. A lot of the real heavy duty Judy's are made in Italy.
   / Rotary tiller questions #14
OP,
At 20 acres a year, how many year's worth of use do you consider acceptable?
I doubt a cheap one from Tractor Supply (or similar) will give you 20-30 years of use. Probably 10? Factor in the cost per year and decide if that's ok with you?
It's only "unbroken ground" the FIRST time you till it. After that, your tiller won't take as much of a beating.
I've always thought of the King Kutter's and similar as "homeowner use" and home garden use type applications.
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A57880)
2018 INTERNATIONAL...
2024 Deere 333D (A53317)
2024 Deere 333D...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
2004 BMW 545i Sedan (A55853)
2004 BMW 545i...
