Rotary Tiller for Mahindra 2816
   / Rotary Tiller for Mahindra 2816 #11
Landpride states 20-40HP should be minimum used on their RTA12 58" and 66" models of tillers. I would imagine other brands have similar HP requirements. You could probably run a 60 fine, and it won't outweigh the tractor's capabilities. The key to doing it and making everything last, is to go slow.
Found something odd about that 2816, either that or tractordata's site has inaccurate info. Tractordata has the HST as having more PTO power (21.5HP HST) than the geared equivalent (20HP gear). Most units lose a bit of PTO power when using a hydro transmission versus gear.
   / Rotary Tiller for Mahindra 2816 #12
2816 will have no problem operating a 60" Tiller.
PALLET OF SHOVELS AND RAKES (A45333)
PALLET OF SHOVELS...
GreatBear 1 Cu Yd Self Dumping Hopper (A44502)
GreatBear 1 Cu Yd...
BORING PULL HEADS (A45333)
BORING PULL HEADS...
PT 1000 Gal Supply Tank (A44501)
PT 1000 Gal Supply...
2006 GMC C8500 Altec AM547 Material Handling Insulated Bucket Truck (A44571)
2006 GMC C8500...
1998 Freightliner FLD120 Sleeper Cab  Detroit Diesel Series 60 Engine, 10-Speed Rockwell (A44789)
1998 Freightliner...
