Tiller rotary tiller annoyance
   / rotary tiller annoyance #1
randy41
Linden VA
this is about the skid depth adjustment. why isn't this built to be easily adjusted? i want to prepare a seed bed so i want it set to max depth. then 15 minutes later i want to cultivate and the min depth would work nicely. but then i have to go get some tools to adjust the skid. theres gotta be a better way.
   / rotary tiller annoyance #2
Yes it does look time consuming. Could you put some type of bolts on it that can be loosened by hand, ie some sort of bolt with a lever on it perhaps going to a welded on nut?
Mike
   / rotary tiller annoyance #3
Sure would help if you said what brand and model tiller you're talking about
   / rotary tiller annoyance #4
I have a Befco roto tiller. Mine has the skids on it, but you can place a push-pull pin in the holes. You know the ones with the ring on them or use a fast removing wing nut on a bolt.
   / rotary tiller annoyance #5
My first tiller did not even have skids so I got used to using the positon control on my 3 Point Hitch. With my new tiller I placed the skids at the highest position possible and just use the positon control for tiller use. I admit changing the skid adjustment is a royal pain so I keep it set at the highest point for the greatest depth for tilling. Jay
   / rotary tiller annoyance #6
I do the same on the depth. Basically I use the same depth all of the time in my garden. Once planted, I switch to my 8.5hp rear tine tiller to get between the rows. The smaller manis type tillers are great for weeding and getting close to plants.
   / rotary tiller annoyance #7
To be honest, I have never adjusted mine. Mine is set near the mid depth position. If I do hard ground, it is all the tiller and tractor can do at that depth. If I want to go deeper, the ground is usually so soft that the skids just dig in deeper and I get deep tilling depth. If the ground is soft and I want to till shallow, I just set the position control on the 3 point. Also, if you have a hydraulic top link, just tipping the tiller forward and backwards will affect the depth.
   / rotary tiller annoyance #8
I have a Befco tiller to but mine has the slots in the skid depth adjustment. Maybe mine are easy to get at but it only takes a couple of minutes with a socket and wrench and your done.
i agree that theres not much to it but if you're out in the field somewhere and you don't have the tools with you then its more than a couple of minutes.
   / rotary tiller annoyance #10
I guess you could set them for maximum depth to start with and then do what jbrumberg does for your cultivating; raise the tiller and control the depth with the position control instead of the skids.
But this conversation DOES give me an idea for a modification to make a hydraulically adjustable skid controlled by the rear remotes. Hmmm.:rolleyes:
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
1275 (A50490)
1275 (A50490)
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
