Tiller rotary tiller annoyance
   / rotary tiller annoyance #1
randy41
Veteran Member
Linden VA
this is about the skid depth adjustment. why isn't this built to be easily adjusted? i want to prepare a seed bed so i want it set to max depth. then 15 minutes later i want to cultivate and the min depth would work nicely. but then i have to go get some tools to adjust the skid. theres gotta be a better way.
   / rotary tiller annoyance #2
Yes it does look time consuming. Could you put some type of bolts on it that can be loosened by hand, ie some sort of bolt with a lever on it perhaps going to a welded on nut?
Mike
   / rotary tiller annoyance #3
Sure would help if you said what brand and model tiller you're talking about
   / rotary tiller annoyance #4
I have a Befco roto tiller. Mine has the skids on it, but you can place a push-pull pin in the holes. You know the ones with the ring on them or use a fast removing wing nut on a bolt.
   / rotary tiller annoyance #5
My first tiller did not even have skids so I got used to using the positon control on my 3 Point Hitch. With my new tiller I placed the skids at the highest position possible and just use the positon control for tiller use. I admit changing the skid adjustment is a royal pain so I keep it set at the highest point for the greatest depth for tilling. Jay
   / rotary tiller annoyance #6
I do the same on the depth. Basically I use the same depth all of the time in my garden. Once planted, I switch to my 8.5hp rear tine tiller to get between the rows. The smaller manis type tillers are great for weeding and getting close to plants.
   / rotary tiller annoyance #7
To be honest, I have never adjusted mine. Mine is set near the mid depth position. If I do hard ground, it is all the tiller and tractor can do at that depth. If I want to go deeper, the ground is usually so soft that the skids just dig in deeper and I get deep tilling depth. If the ground is soft and I want to till shallow, I just set the position control on the 3 point. Also, if you have a hydraulic top link, just tipping the tiller forward and backwards will affect the depth.
   / rotary tiller annoyance #8
I have a Befco tiller to but mine has the slots in the skid depth adjustment. Maybe mine are easy to get at but it only takes a couple of minutes with a socket and wrench and your done.
i agree that theres not much to it but if you're out in the field somewhere and you don't have the tools with you then its more than a couple of minutes.
   / rotary tiller annoyance #10
I guess you could set them for maximum depth to start with and then do what jbrumberg does for your cultivating; raise the tiller and control the depth with the position control instead of the skids.
But this conversation DOES give me an idea for a modification to make a hydraulically adjustable skid controlled by the rear remotes. Hmmm.:rolleyes:
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2016 Ford Fusion SE AWD Sedan (A50324)
2016 Ford Fusion...
2013 BMW 528i Sedan (A50324)
2013 BMW 528i...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2016 Volvo SD45 Smooth Drum Roller (RIDE AND DRIVE) (A50774)
2016 Volvo SD45...
