Rotary Tiller Advice
/ Rotary Tiller Advice #1
JME81
New England
Kubota LX2610HSDC
I have a Kubota LX 2610 tractor. Rear PTO is 20. My rear tire width is 54".
I want to get a tiller and there are two options locally that I've found:
  • Iron Craft - 48", 20-25 PTO
    • *Gear driven: $2190
  • Land Pride - 50", 15-25 PTO
    • *Gear driven: $2750
Iron Craft is $560 cheaper than the Land Pride. Both have a slip clutch and gear driven. Both also do have a chain version as well. 60" tillers are out of my price range.
I'm not sure if I should go with chain or gear drive?
Usage
  • The ground is average, no clay that I have seen
  • Making rows for corn, maybe 5 x 50' rows
  • Making rows for rasperries
  • Making rows for various vegetables
  • Possibly cleaning up areas of the field to re-see but that would be minimal
/ Rotary Tiller Advice #2
I think mine is a chain drive in a sealed oil bath, but not sure. I would be looking at tillers that cover your width, especially since you do not seem to have particularly challenging soil conditions.
60" wide tillers require a larger rear PTO. The rear tires are a little larger which puts them over slightly.
/ Rotary Tiller Advice #4
If the price is right a slightly narrower may do depending on usage.
When I was first NEEDING a tiller (back in ~2009) I had only my B7610. Then I got my M4700. Shortly after I got my 48" tiller for ~$600. Ended up tilling ~1/8 acre of clay using the 4700 and small tiller. Worked for me. The B7610 couldn't pull the tiller through clay.
Usage
2020 HUNTER AUTOMATIC TIRE CHANGER (A59909)
2020 HUNTER...
2013 Ford Escape SUV (A61569)
2013 Ford Escape...
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
UNUSED ATS DJ2200 ELE. LIFTING MOTOR (A62131)
UNUSED ATS DJ2200...
2021 John Deere 333G Skid Steer (A63109)
2021 John Deere...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61567)
2025 JMR 72in...
