rotary pump & filter? / fuel dribble?
   / rotary pump & filter? / fuel dribble? #1
daveinnh
Hillsboro, NH
Kubota L4310
I'm looking at a 55 gal. steel tank at Northern Tool with a manual rotary pump.
Some of the 12V pump packages at N-T and elsewhere provide for a fuel filter - can / should a manual pump be equipped with a fuel filter?
(Need tank since we have a Kubota L4310 and lifting a 5-gal Poly tank 2x / week over the hood becomes slippery in winter.)
Followup ques: would a typical rotary pump / hose/ nozzle (loaded on ground)discharge the remaining fuel from the hose after operation from hood height?
   / rotary pump & filter? / fuel dribble? #2
I think adding a filter to a manual pump might add a bit of resistance making it harder to crank.
   / rotary pump & filter? / fuel dribble? #3
I've pumped a lot of fuel through a manual pump with a filter. The benefits of a filter are worth it.
   / rotary pump & filter? / fuel dribble? #6
That's an entirely different discussion. *If someone has a storage tank with any kind of pump, there should be a filter involved, IMHO.
*I agree.
I was just sayin A drum and a 12 volt pump might be a better option than a tank and a hand pump.
I have $69 in a 12 volt pump and $17 in a 55 gallon drum.
I don't know what the OP is looking at for the 50 Gallon tank and hand pump.
   / rotary pump & filter? / fuel dribble? #7
And use a filter that stops the water.
   / rotary pump & filter? / fuel dribble? #8
Just finished building a fuel caddy,I had a previous post looking for suggestions, I've got $40.00 in material which is 20'' sch. 10 stainless pipe,1/4'' plate for end caps. It is 3'high I just filled it and it holds 46gallons of diesel.I bought a rotary pump from tughill, that was $160.00 but I,ll tell ya it was well worth the extra money, my 2305 holds 5.5 gallons near empty it took only 3 minutes to fill it and thats with a in line filter for water and particles which I bought at TSC for $28.00.
   / rotary pump & filter? / fuel dribble? #9
1*Just finished building a fuel caddy.
I've got $40.00 in material which is 20'' schedule 10 stainless pipe,1/4'' plate for end caps.
2*I just filled it and it holds 46 gallons of fuel.
3*I bought a rotary pump from tughill for $160.00 but I'll tell you it was well worth the extra money,
1*Please post some pictures of this.
I'd like to see how you plumbed it all up and how you mounted the pump.
We all like pictures.
2*Was that off road fuel?
3*My pump is rated for 10 gallon PER minute.
What's this one rated at?
   / rotary pump & filter? / fuel dribble? #10
I'm in the process of getting set up to send pics , should be by the end of this week.The pump is rated for 10 gallons per 100 revolutions but it seems alot faster than that.If you have a northern tool catalog its on page 339, however I bought mind at grainger, there is a store not far from me.
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
JOHN DEERE 1725 CCS LOT NUMBER 29 (A53084)
JOHN DEERE 1725...
JOHN DEERE 7210R LOT NUMBER 268 (A53084)
JOHN DEERE 7210R...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
