rotary pump & filter? / fuel dribble?
   / rotary pump & filter? / fuel dribble? #1
daveinnh
Hillsboro, NH
Kubota L4310
I'm looking at a 55 gal. steel tank at Northern Tool with a manual rotary pump.
Some of the 12V pump packages at N-T and elsewhere provide for a fuel filter - can / should a manual pump be equipped with a fuel filter?
(Need tank since we have a Kubota L4310 and lifting a 5-gal Poly tank 2x / week over the hood becomes slippery in winter.)
Followup ques: would a typical rotary pump / hose/ nozzle (loaded on ground)discharge the remaining fuel from the hose after operation from hood height?
   / rotary pump & filter? / fuel dribble? #2
I think adding a filter to a manual pump might add a bit of resistance making it harder to crank.
   / rotary pump & filter? / fuel dribble? #3
I've pumped a lot of fuel through a manual pump with a filter. The benefits of a filter are worth it.
   / rotary pump & filter? / fuel dribble? #6
That's an entirely different discussion. *If someone has a storage tank with any kind of pump, there should be a filter involved, IMHO.
*I agree.
I was just sayin A drum and a 12 volt pump might be a better option than a tank and a hand pump.
I have $69 in a 12 volt pump and $17 in a 55 gallon drum.
I don't know what the OP is looking at for the 50 Gallon tank and hand pump.
   / rotary pump & filter? / fuel dribble? #7
And use a filter that stops the water.
   / rotary pump & filter? / fuel dribble? #8
Just finished building a fuel caddy,I had a previous post looking for suggestions, I've got $40.00 in material which is 20'' sch. 10 stainless pipe,1/4'' plate for end caps. It is 3'high I just filled it and it holds 46gallons of diesel.I bought a rotary pump from tughill, that was $160.00 but I,ll tell ya it was well worth the extra money, my 2305 holds 5.5 gallons near empty it took only 3 minutes to fill it and thats with a in line filter for water and particles which I bought at TSC for $28.00.
   / rotary pump & filter? / fuel dribble? #9
1*Just finished building a fuel caddy.
I've got $40.00 in material which is 20'' schedule 10 stainless pipe,1/4'' plate for end caps.
2*I just filled it and it holds 46 gallons of fuel.
3*I bought a rotary pump from tughill for $160.00 but I'll tell you it was well worth the extra money,
1*Please post some pictures of this.
I'd like to see how you plumbed it all up and how you mounted the pump.
We all like pictures.
2*Was that off road fuel?
3*My pump is rated for 10 gallon PER minute.
What's this one rated at?
   / rotary pump & filter? / fuel dribble? #10
I'm in the process of getting set up to send pics , should be by the end of this week.The pump is rated for 10 gallons per 100 revolutions but it seems alot faster than that.If you have a northern tool catalog its on page 339, however I bought mind at grainger, there is a store not far from me.
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2000 Isuzu NPR-HD Landscape Truck, VIN # 4KLC4B1R9YJ802689 (A51572)
2000 Isuzu NPR-HD...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
