Rotary plow seals
   / Rotary plow seals #1
Dan Reyes
Wenatchee
Gravely com10a, Ford8n
Does anybody know the napa's part number for the upper and lower seals? My lower seal is starting to leak thanks
   / Rotary plow seals
Thanks I'll pull the old one and take a trip down to napa
   / Rotary plow seals #4
I have done some research into the original seals and I am not even sure that Gravely has them any more. THey are an oddball. They look like two standard seals back to back in a common retainer. I ordered a few standard seals today for a plow I am rebuilding. I will see how they fit. The dimensions of the original seal I have is 2.250 x 3.250 x .690
Maybe the best solution is to call Richard's.
   / Rotary plow seals #5
I'd say Richard has the right idea. I tried to cross over the Gravely # for the bottom seal in my 30" bush hog and came up empty. Got me one comin' though. Let me know if NAPA's seal was even close. Parts cross reference works sometimes, sometimes not.
Kelly
   / Rotary plow seals #6
The seals that I ordered are from TCM/Dichtomatic. The seal number is 22323TB-BX
While narrower than the original seal, they fit just fine. I could have gone with two 1/4" wide seals and stacked them but the 1/4" wide seals do not have a garter spring. I order Dichtomatic seals through Accurate Bearing.
2018 John Deere 1653 (A55302)
2018 John Deere...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
Brock 5 Ton Feed/Grain Tank (A55218)
Brock 5 Ton...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
PALLET OF SCAFFOLDING (APPROX. 19 PC) (A52706)
PALLET OF...
Hyster H225E Forklift (A47477)
Hyster H225E...
