Rotary Plow on a BCS 716
   / Rotary Plow on a BCS 716 #1
Trailking26
New York, NY
I'm looking to get a machine that will break up rocky, compacted soil for manual excavation/grading in confined/limited access situations and trailbuilding applications.
I have found a used BCS 716 at a decent price on the local listserv that comes with a standard tiller.
I also found a used BERTA rotary plow which id like for its increased digging depth and ability to handle rocky soils.
I checked the compatibility chart and my question is this;
It is not stated to fit the 716 on the compatibility chart. Would the BERTA plow in fact fit my 716?
If the power is going to be an issue, how big of a power swap can I do on the tranny, and will it be enough?
I do like the 716 because it appears to have a smaller footprint than the bigger machines, and we do have a shortage of storage space to contend with.
I did a search on several sites but this kind of info seems to be getting harder to find.
Thanks for your inputs,'
-Christopher
   / Rotary Plow on a BCS 716 #3
Earth Tools
Useful info here. Recommends a minimum of 8.5HP gas engine.
Note also the issue of needing weight up front to counterbalance the rotary plow, when e.g. it is neccesary to lift up the back, such as when turning around at the end of a bed.
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
Set of AG R4 Wheels and Tires (A53472)
Set of AG R4...
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
PRO WORKS PWFF LOT IDENTIFIER 143 (A53084)
PRO WORKS PWFF LOT...
