Rotary mower repair
   / Rotary mower repair #1
MESSMAKER
Bluegrass,KY
DK4710SE
The gearbox became a bit loose and it cracked the plate slightly around one of the holes on the mounting plate. I need to repair.
1-Take off gearbox and cut out the plate and replace.
2-take off gearbox and mount a 1/4" plate on top
3-weld a plate over the cracked area
What would you guys do?
   / Rotary mower repair #2
Mostly I just grind out cracks and weld.
But if you take off the gear box and post pics, the advice is easier to give.
   / Rotary mower repair #3
After removing the gear box, I would start by grinding out the crack, fill back with 7018 weld metal. Then if you think the gear box mounting is a bit weak, add a 1/4" plate to the top. Weld it solidly all the way around and if the area is large enough, add some 3/4-1" plug welds on the interior (at least 4) to firmly attach the new plate to the old one.
A plug weld is done by drilling or cutting a round hole in the top plate large enough that you can weld the under side plate to the top plate. This basically make both plates into one unit.
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
2002 International 9200i Truck (A53472)
2002 International...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53472)
2016 Ford F550 4x4...
2018 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53472)
NEW 2024 LOAD...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
