Rotary mower repair
   / Rotary mower repair #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
The gearbox became a bit loose and it cracked the plate slightly around one of the holes on the mounting plate. I need to repair.
1-Take off gearbox and cut out the plate and replace.
2-take off gearbox and mount a 1/4" plate on top
3-weld a plate over the cracked area
What would you guys do?
   / Rotary mower repair #2
Mostly I just grind out cracks and weld.
But if you take off the gear box and post pics, the advice is easier to give.
   / Rotary mower repair #3
After removing the gear box, I would start by grinding out the crack, fill back with 7018 weld metal. Then if you think the gear box mounting is a bit weak, add a 1/4" plate to the top. Weld it solidly all the way around and if the area is large enough, add some 3/4-1" plug welds on the interior (at least 4) to firmly attach the new plate to the old one.
A plug weld is done by drilling or cutting a round hole in the top plate large enough that you can weld the under side plate to the top plate. This basically make both plates into one unit.
2022 John Deere 4066M Heavy Duty MFWD Tractor (A53342)
2022 John Deere...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
