prof fate
Platinum Member
- Joined
- May 30, 2018
- Messages
- 684
- Location
- beaver pa
- Tractor
- kioti ck3510 Cub Cadet 149, 2146, Toro Zero Turn
There are 3pt and pull brush hogs (rotary mower) - wen they start to get big (and heavy) the pull behind is the preferred choice. 6' and up you usually have the choice. pull behind's cut a bitbetter as they ride mroe consistently - but depends on the area you're mowing - lots of backing up then a 3pt is a better choice.
I've not noticed much diff in speed with 10" weeds vs 4' weeds. Some are thicker than others and uphill means going slower as HP is sucked up with climbing the hill.
I'm currently mowing 18-20 acres of horse pasture with a 29hp pto HST tractor and 6' bush hog brush hog. The 'rule of thumb' is 1' of hog for every 5 pto hp. I could probably do a 7'. Last tractor has 15pto hp and was geared and i pulled a 4' king kutter. It worked, but toook more time.
Some of the grass will stand back up- brush hogs don't 'suck' up the grass like lawn mowers and the wheels will compress it and it won't get cut fully. The taller the weeds the more you'll notice this. a second cut a few days later will correct it.
I've nto used a flail mower, but from my research it takes more HP for the same size cutter, a LOT more maintenance (more parts, more blades) but will give a nicer finish.
An 8' pull behind should work for you - again, terrain and conditions may be a consideration.
You can find used ones for less than half the price of new.
