Rotary Mower for BX22
   / Rotary Mower for BX22 #1
dmartin88
Leesburg, Virginia
Kubota BX22, Bobcat 763H
Looking to purchase a rotary mower for my BX22. Main use will be mowing a 1 acre "meadow" once or twice per year and to create/maintain some paths through the woods on our property (4 acres). Looking at the Rhino SE42, figure the smaller size is appropriate for the horsepower of the BX22 but would be interested if others have this combination and how happy they are. Would use a chainsaw to clear any of the larger trees when making the paths the first time so really looking at the longer term for the SE42?
   / Rotary Mower for BX22 #2
When I had my BX2200 I used a 48" Bushhog. It worked most of the time. A few times in very thick grass I has to slow down. I also cut some pretty big sapplings. If you go slow it should do 1.5" with no problem.
   / Rotary Mower for BX22 #3
I used (and still have) a 48" HOWSE bushhog. I had to reverse the lift pins but it worked fine. Be sure you remember you have low ground clearance. You don't want to tear up the bottom side of the BX /forums/images/graemlins/grin.gif
STORAGE FEES (A52577)
7021 (A50322)
7021 (A50322)
2014 FORD E-350 11 PASSENGER VAN (A52472)
2014 FORD E-350 11...
Generac Generator (A51691)
Generac Generator...
2015 Peterbilt 320 Truck (A51692)
2015 Peterbilt 320...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
