Rotary Mower for BX22
   / Rotary Mower for BX22 #1
dmartin88
Leesburg, Virginia
Kubota BX22, Bobcat 763H
Looking to purchase a rotary mower for my BX22. Main use will be mowing a 1 acre "meadow" once or twice per year and to create/maintain some paths through the woods on our property (4 acres). Looking at the Rhino SE42, figure the smaller size is appropriate for the horsepower of the BX22 but would be interested if others have this combination and how happy they are. Would use a chainsaw to clear any of the larger trees when making the paths the first time so really looking at the longer term for the SE42?
   / Rotary Mower for BX22 #2
When I had my BX2200 I used a 48" Bushhog. It worked most of the time. A few times in very thick grass I has to slow down. I also cut some pretty big sapplings. If you go slow it should do 1.5" with no problem.
   / Rotary Mower for BX22 #3
I used (and still have) a 48" HOWSE bushhog. I had to reverse the lift pins but it worked fine. Be sure you remember you have low ground clearance. You don't want to tear up the bottom side of the BX /forums/images/graemlins/grin.gif
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
