Mowing Rotary mower by Brown Manuf. ??
   / Rotary mower by Brown Manuf. ??
The offset rotary cutters I've seen are pretty big and heavy. That's good for laying the 2" stuff over for grinding it up but you may find the L4310 on the small/light side to really handle that much implement.
Have you given any thought to a high-speed disk mower? I had a 7-foot Vicon which would saw through 2" (max) stuff if I went slow. Of course this was really a grass mower which I shouldn't have used that way but it sure worked. It had a lift cylinder which would stand it up to do vertical hedges ! Kuhn makes one in the 5-6 foot range which would work on the L4310. One warning though - if your place is rocky don't even think about a disk mower. Cost to fix is fierce if you jam it up.
   / Rotary mower by Brown Manuf. ?? #12
rbargeon,
I looked at the disk cutters and they were quite expensive. I have a lot of rocks and wanted to be able to find a cutter that would work for sides of ditches as well as cut hay on a small scale, but am still looking.
wen: Of all the mowing machines I've had, the one which is has been useful the longest is a Sperry-New Holland (red) model 451 sicklebar. This unit is a very well thought out design, using a frictionless knife drive, all-mechanical lift, reliable breakaway - in short everything you'd want for ditches and small-scale haying. It will cut up to 1" saplings. The newholland website shows it at http://www.newholland.com/na/Products/Sicklebar.html
It has changed very little over the twenty+ years they've made it - good evidence that the design is right.
Wow! I just called a local NH dealer - current price of a new 7' model 451 is over $4k ! This is major motivation to find a good used one - most people who own an older one probably got it for 2k or less. All the wear parts are readily available so buying new for this much money seems out of line.<P ID="edit"><FONT SIZE=-1>Edited by rbargeron on 7/21/00 11:08 AM.</FONT></P>
   / Rotary mower by Brown Manuf. ?? #14
Thanks for the info. Yes, that is the problem I continue to have is that the new attachments have become very expensive. I have a horse drawn sickle bar, but it is a little too rusty to fix. Nice design, though.
   / Rotary mower by Brown Manuf. ?? #15
ok I found that woods does make an offset but it is too light to handle what you want, but also hardee williams makes a pretty good looking offset it comes in five and six foot models with dual wheels or a single wheel, with your choice of right or left offset. the 5 ft. weighs approx. 820lbs and the six ft. approx. 930lbs with a 90hp. gear box on either one, 7 gauge deck, skids are 3/8"+ 3" cutting height 2" to 12" stump jumper and slip clutch, round stump jumper,cat 1, .... I think their website is www. hardeewilliams.com or it may be www.hardee.com something like that... hope this helps and good luck... oh yeah list price on the 5' is 2,390 and the 6' list is 2,430 list on 6' with dual wheels is 2,700. hardee makes good durable equip. i sell alot of their cutters if that is the wrong web site you can call them at, 1-800-588-9263
   / Rotary mower by Brown Manuf. ?? #16
   / Rotary mower by Brown Manuf. ?? #17
glad to help gordon.... you should really check the hardee boys out.....
   / Rotary mower by Brown Manuf. ?? #18
TenneseeMike (& Gordon) - Thanks for the information! I'll check them out. I hadn't heard of them before. I'll let you know what I find.
Mark
   / Rotary mower by Brown Manuf. ?? #19
Dick,
Is Wen {W5FL}, the same as Astronaut Owen Garriott, W5FL?
I emailed WEN to see where he went?
   / Rotary mower by Brown Manuf. ?? #20
John—Hope you will let us know if you hear back from Wen. He has not been around for a year now. He always had great information to share. Sure hope everything is OK.
MarkV
2005 International 4300 Telsta Telescopic Bucket Truck (A55973)
2005 International...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
CATERPILLAR 289D SKID STEER (A52709)
CATERPILLAR 289D...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 Chevrolet Equinox LTZ AWD SUV (A56859)
2013 Chevrolet...
2016 Ford Explorer AWD SUV (A54815)
2016 Ford Explorer...
