Rotary lasers are awesome
   / Rotary lasers are awesome
If you are in the market for a laser, take a look at this product before you buy one: ZIPLEVEL(R) PRO-2 High Precision Altimeter Replaces Rotary Lasers
I recently had some work done on my property and the contractor had one of these. The base price is less than $1000. Its amazing, and, it can be operated single handed. I was very impressed. The contractors swear by it.
That is pretty neat for certain applications. The fact that the two endpoints are connected by a cord would be a limiting factor for me. My laser has a range of 3000’. If you measure the distance you could stakeout a slope with the zip level but that would be more complicated than just setting a laser to a certain percent grade. The zip level would be pretty good for flatwork.
I didn’t buy my laser outright. It came as a part of a package deal with my machine control grader for my skid steer. I just am finding it useful for other things.
   / Rotary lasers are awesome #12
On the opposite end I bought the $28 HF laser level to set up the footers for my metal barn. Fairly time consuming process with the cheap setup but when my SIL brought over a Bosch professional unit the results were exactly the same. The pro unit took about 10 minutes to set up and measure vs an hour with the cheap level.
I did have to make my own grade stick to use the HF level. That consisted of a piece of plywood for a flat base with a 2x2 screwed to it and a aluminum yard stick screwed onto that.
   / Rotary lasers are awesome #13
I also just recently purchased the ProShot Alpha C con laser. Construction level tools - L6C laser product page
I have at least four baseball/softball fields to grade in the next few months, and this laser allows for 'cone' shaped grades. As far as I know, it is only used for construction of baseball/softball fields, and maybe running tracks. I had been borrowing one from a friend, but I felt it was worth the $2500 for me to own my own unit.
Now I can build/grade football and soccer and baseball fields and probably many other things.
The GPS grading setups are amazing but $$$. You can take the engineers design and load it right in to your machine and grade it out.
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
Cushman Electric Cart (A55851)
Cushman Electric...
No runner (A56859)
No runner (A56859)
2003 Big Tex 10PI...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
300 GALLON PULL BEHIND SPRAYER TANK (A57192)
300 GALLON PULL...
