rotary cutter
   / rotary cutter #1
deereman64
I hit a stump yesterday. The blades folded, but it certainly made the engine stutter. Can you damage an engine through undue force from a pto?
   / rotary cutter #2
short answer : YES
do you have a slip clutch or shear pin protected pto? I would assume you have the clutch set too strong or too high a grade bolt in shear pin. There are several threads going about each. If it shuddered the engine something should have "givin" first.
   / rotary cutter #3
Even with a slip clutch or shear bolts, you can do damage, though generally damage is done to PTO shaft/clutch/transmission. I helped change an engine on an old Massey Ferguson 35 a few years back, where the rear flange of the crankshaft snapped off when a bush hog hit a big rock. Slip clutch didn't give. Crankshaft did. Massey's have a coupling in the tranny (in PTO driveline) that SHOULD have let go, preventing this disaster
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2022 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A51692)
2022 Mercedes-Benz...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
BUSH HOG 1815R1 BATWING MOWER (A51247)
BUSH HOG 1815R1...
