Rotary Cutter Rotary cutter
/ Rotary cutter #11
I have a 297, dual tail wheels and chains front and rear. It's a beast. I use it to mow about 40 acres distrituted amongst 7 fields. I've easily cut into some 4 inch trees. I try not to do that to often though. I'm using it behind a CX90 ~80 HP.
/ Rotary cutter
The 326 is just a 6' cutter, the 327 is 7', btw.
Yea, that was a PHP fatal error. I should have said 327.
I sure do hope you guys do not get mad at me about my comment in post # 8. There is a lot of knowledge on this forum.
Thanks Todd. I looked at a medum duty JD rotary cutter where I bought my tractor. The owned brought it back with a busted gear box [I think]. I will be cutting around a lot of stumps.
More than likley, the 4" will be cut with an old Husky 266XP.
Mike
/ Rotary cutter #13
I run a Landpride RCR3596,been really happy with it.
/ Rotary cutter #14
Unless you are buying new to take advantage of some financing deal, go used. Search Used Tractors For Sale at TractorHouse.com: John Deere Tractors, used farm tractors and farm equipment, tractors for sale, Case IH, New Holland, Agco, Kubota You'll find a lot of variety and prices. I bought a used JD model 1008, dual spindle, 10', four rear wheels, heavy duty cutter for $1800. It had been used as a finish mower.
Someone mentioned a Bush Hog 3210. They are an excellent heavy duty cutter and can be bought in excellent condition used for $3000-$4000 depending on location.
I also suggest a dual spindle.
2018 CATERPILLAR 262D SKID STEER (A62129)
2018 CATERPILLAR...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59906)
2004 VOLVO VHD...
Kubota L2502 (A60462)
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
