Rotary cutter to quick hitch bushing question
   / Rotary cutter to quick hitch bushing question #11
Check with TSC they have lots of bushings that will work
willy
   / Rotary cutter to quick hitch bushing question #12
If you spent $1500 on a lathe you can make your own and save $5.
   / Rotary cutter to quick hitch bushing question #13
just take a 1/4X1 strap and bend around the 7/8 bar or 1 inch if you want a little
play and weld in , you will never need the adapters for the pens
AnDx4tP.jpg[img]
Always modify the implement, not the hitch
   / Rotary cutter to quick hitch bushing question #16
THE QH is a "standard".... Always bring non standard implements into match the standard, life gets simpler for hook up after that....
when a set goes for 20 to 35.00 a set of bushings and you need 5 or more sets ,, a simple 1/4 inch strap will do Duh ....
   / Rotary cutter to quick hitch bushing question #17
I'm cheap. I run without bushings, aside from that photo I posted above with the additions on the towbar that keep the trailer ball upright.
I can't think of anything I do where the added precision gained by bushings could make any difference. For mowing, rototilling, and for the pallet forks attachment, stabilizing the small amount of slack wouldn't be of any value.
2016 Chevrolet Express 2500 Passenger Van (A55973)
2016 Chevrolet...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
WESTFIELD 6" AUGER (A52708)
WESTFIELD 6" AUGER...
MILWAUKEE SAWZALL W/ CASE (A58374)
MILWAUKEE SAWZALL...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
