Rotary Cutter Rotary Cutter size
   / Rotary Cutter size #11
</font><font color="blue" class="small">( He could go with the SE8 "pull type" and be ok as it has a minimum pto horsepower requirement of 30.
)</font>
You know.. I've always found that funny... I've also seen reduced hp numbers on pull type mowers compaired to equal sized / same manufacturer 3pt mower. My 10' 3pt mower reccomends more hp than the pull type.. etc.
What gives.. the gear box is the same.. why would the 3pt mower need more pto hp? than the pull type?
Soundguy
   / Rotary Cutter size #12
</font><font color="blue" class="small">( What gives.. the gear box is the same.. why would the 3pt mower need more pto hp? than the pull type?
Soundguy )</font>
It makes me wonder if cutter manufacturers are considering only HP or of they're also considering tractor weight.
   / Rotary Cutter size #13
some of them like rhino have a seperate lifting hp and pto hp. I think they are generalizing how much weight a tractor should be able to lift based on engine hp. If this is the case then you just go by what your manual says your tractor can lift with the 3pt and make sure it can handle the implement, and make sure the pto hp is greater than the minimum for the implement.
2005 Peterbilt 387 with Wet Kit (A55314)
2005 Peterbilt 387...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A53421)
2024 AGT LRT23...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2021 INTERNATIONAL MV607 (A55745)
2021 INTERNATIONAL...
2018 FOREST RIVER KNIGHT FIRE SUPRESSION (A55745)
2018 FOREST RIVER...
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
