Rotary cutter size question for a CK20s HST
   / Rotary cutter size question for a CK20s HST #21
Where is a good place to pick up a 54 "rotary cutter .. Not having much luck locating one .
Just go with a 60". Bobcat had 3 rotary cutters for their Kioti equivalent line up, a 5' for the CT122/CK20, 5' or 6' for the CT2xx/CK27-35, and 6' or 7' for the 335 & 4xx/DK models. Some of the concern about too wide cutter is the weight, tail wagging the dog problem, but the Kioti is heavy enough to handle a medium duty cutter in appropriate width with no problem.
   / Rotary cutter size question for a CK20s HST #22
Anyone know what size rotary cutter is best for the Ck 20s HST 4or5 foot ~one dealer said a 5 foot would work another said stay at 4feet .I am confused planing on getting a new CKS 20 HST and cutter this week ... :confused2:Thanks Jeff
Pooter, I have used both a 4' and 5' foot cutter. I borrowed a 5' for cutting an open field with just tall grass. I bought a heavy duty 4' foot cutter with a 60 hp gear box for the ruff stuff. I am of the opinion, if I can run it over, I can mow it. LOL. One note, I am running the manual transmission which gives me 2 more HP to the PTO. I don't know if that will make a big difference, but it might. One more thing. Make sure it has a true stump jumper.
   / Rotary cutter size question for a CK20s HST #23
I had the older version of your tractor in gear drive I ran a 5 footer and a four footer on it. It handled the five footer however it was a bit much for it and it was very heavy on the three point. I kept running into things on the side of it when I was mowing up close to stuff. Sold it and bought a four footer and was much happier.
Kubota RTV X900 (A53317)
Kubota RTV X900...
1974 John Deere 6030 Tractor (A55315)
1974 John Deere...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A56858)
2013 International...
2017 Ford F-350 Crew Cab Pickup Truck (A55973)
2017 Ford F-350...
2013 International Derrick Digger Truck (A55973)
