Rotary Cutter Rotary cutter: Rhino vs. Bushhog?
   / Rotary cutter: Rhino vs. Bushhog? #11
$65, i have got to locate agrisupply, the cheapest i can find around here is $100.
thanks
heehaw
   / Rotary cutter: Rhino vs. Bushhog? #12
I have a Woods brushbull of that size and spent about the same amount of money. I've cut light brush with it! /forums/images/graemlins/cool.gif Love it!
   / Rotary cutter: Rhino vs. Bushhog? #13
</font><font color="blue" class="small">( I have a 48" King Kutter rotary mower ($675 at Tractor Supply Co.) )</font>
YOWZA! /forums/images/graemlins/shocked.gif
I called earlier this year because I have a 4 footer I wanted to sell and they were $545! I'm glad I didn't get enough gumption to advertise it. This spring I should be able to make a good dollar on it. I feel like I'm holding onto gold.... /forums/images/graemlins/wink.gif
   / Rotary cutter: Rhino vs. Bushhog? #14
They have a sale on a 1 3/8 shaft model for $60.95. Be sure to enter the site using Farm & Tractor. You end up in the trailer section if you enter from another page. agri-supply
   / Rotary cutter: Rhino vs. Bushhog? #15
I have a SQ480. I used it to cut two acres of neglected farm. It worked well behind my 15HP Kubota. The Bushhog literature says it is good up to 1" dia. brush. Find out what the Rhino can cut. That should help you decide.
   / Rotary cutter: Rhino vs. Bushhog? #16
I have a Rhino SE6 and love it so far,I have used both and the Bush Hogs are tough I have one that they should put in the hall of fame at Bush Hog. But it seems to me that the Rhino is built a little better by the design of it. I have replaced many tail wheel assemblies on the Bush Hog from them not being very rigid in the support system. It has flat metal welded to the round stock that the tail wheel goes thru and they bend a little to easy. The Rhino has square tubing for the tail wheel support and seems to be pretty strong. I would spend the extra money to get a slip clutch.But that is just my 2 cents.
   / Rotary cutter: Rhino vs. Bushhog? #17
found it, thanks...not sure what the shipping will be yet, but it will surely save me some $$ over the $100 local price:
maybe i'm wrong, as i tend to be that way, more often than not : but i have a B7510 Kubota, and i am more concerned about what it will do than what the rhino or bush hog cutter will do: seems like a cheaper light weight cutter would do everything the 7510 would?
heehaw
   / Rotary cutter: Rhino vs. Bushhog? #18
It depends on how hard you intend to abuse the cutter. I think the cheapo cutters are probably perfectly fine for mowing meadows etc. If you are clearing land and hitting stumps, saplings, rocks etc it would pay to get one of the better brands.
   / Rotary cutter: Rhino vs. Bushhog? #19
i'm not sure how much clearing, hitting stumps etc a person is going to do with a 17 pto hp tractor? i'd a whole lot rather tear up that cheapo cutter than the tractor. that said, i have been accused of being able to tear up an anvil with a rubber mallet.
heehaw
   / Rotary cutter: Rhino vs. Bushhog? #20
Even hitting stumps and rocks, IMHO a light duty cheap rotary mower is probably all most of us need unless we are planning to use the mower to bulldoze down trees. I have had a variety of mowers of the light duty, el cheapo type and never damaged the gear box or tractor using only the shear pin model. I think the heavy duty decks will last longer because they won't rust out as quick if they are made of heavier guage metal and they are left to sit out for long periods of time. This is generally what goes in my opinion (the deck) rather than the gear box. Even then, you can weld some additional plates on and it will cost you less than getting the more expensive mower to begin with. I have had it done with a mower that was almost rusting through and dangerous and then sold it in still good working order.
Most of the better quality mowers cost twice what the lighter duty ones cost and yet most of us won't wear out the first one, let alone two.
2005 Suzuki King Quad 700 Fourwheeler (A57453)
2005 Suzuki King...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
Aerator Roller (A57454)
Aerator Roller...
Fencing (A56859)
Fencing (A56859)
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
