Rotary Cutter Rotary cutter: Rhino vs. Bushhog?
   / Rotary cutter: Rhino vs. Bushhog? #1
Cyberchuck
I'm going to buy a rotary cutter for my Kubota B7500 (17 PTO hp).
My local dealers have a Rhino SE-4 for $915, or a BushHog brand SQ480 for $795. Both are 48", and to me look pretty similar.
My question is whether the Rhino is worth the extra $120. I don't mind paying more if I'm getting better durability, better service parts availability or something else tangible.
Is the Rhino worth it, or should I save the $120 and go with the BushHog?
TIA,
Chuck
Athens, GA
   / Rotary cutter: Rhino vs. Bushhog? #2
The Rhino is better than the Bushhog, but you can't go wrong with either model.
   / Rotary cutter: Rhino vs. Bushhog? #3
Does the Rhino have a slip clutch on it? That might be where the price difference is coming from. I would imagine at that price the Rhino has a slip clutch, the SQ480 isn't offered with it. If they are both shear pin protection then the Rhino would not be worth the extra money.
   / Rotary cutter: Rhino vs. Bushhog? #4
I can't compare them for you but I have the SQ480 and can't imagine needing more ($) cutter (for the size). Great unit.
Good point about the slip clutch vs cost though. If that's the case, and you do your own work, AgriSupply has slip clutches for ~$65.
A note about the BushHog shear pin ... mine came (setup by idiot dealer) with a grade 5 bolt/shear pin. I replaced it with a grade 2 (per manual).
Cheers!
   / Rotary cutter: Rhino vs. Bushhog? #5
You might want to consider a Bush Whacker too. They are very solid chunks of equipment. Of course, not everyone needs a heavy duty unit like it.
When we were looking for a new rotary unit, we found a pretty good difference in price on Bush Hogs from one dealer to another. Shopping around might get you a slightly better deal. Not sure about the Rhinos as we didn't price them.
   / Rotary cutter: Rhino vs. Bushhog? #6
Never seen the Rhino but I own and am very happy with the BushHog model you are considering. $795 is a good price too.
   / Rotary cutter: Rhino vs. Bushhog? #7
Also make sure that the BushHog has the laminated trail wheel not the solid tire...you will thank yourself.
   / Rotary cutter: Rhino vs. Bushhog? #8
I have the Rhino SE-5 and L3400. Can't speak for the Bush Hog but I can't imagine a tougher unit than the Rhino. Mine gets put through some tough duty and rough terrain. Breaks a shear pin now and then but that's what it is supposed to do. I am impressed with the quality and heaviness of the housing, etc.
   / Rotary cutter: Rhino vs. Bushhog? #9
I have a 48" King Kutter rotary mower ($675 at Tractor Supply Co.) for my B7510HST (21HP engine, 17HP at the PTO). It comes with a PTO shaft that has a shear bolt, but you could install a slip clutch without a lot of trouble if that's your preference.
I use it for weeds (don't have any heavy brush or small saplings on my 10 acres) and it works fine. The 7510 has no trouble handling this beastie.
KK has a reputation for making no-frills, relatively inexpensive stuff that gets the job done. Some folks here consider KK stuff to be cheap enough to throw away rather than bother with an expensive or time-consuming repair.
   / Rotary cutter: Rhino vs. Bushhog? #10
Hey,
I have a Bush Hog SQ600 Squealer rotary cutter. I gave $890.00 for it back in February. I don't think I could have bought anything better for the money. I knew about the Rhino cutters, but all we have around here mainly is Bush Hog and the cheaper units.
I have put my squealer through things you probably wouldn't imagine....gotta give a shout out to my Mahindra tractor too, very tough... /forums/images/graemlins/grin.gif...but anyway, I have only sheared the pin 2 times. Both times were from unseen stumps. I have cut at least 4" ironwood trees with it. Not to mention all the brush and cottonwood trees.
I don't think I will ever buy a cutter with a slip clutch. I don't see where a person would need one. Unless its just preference. I have been VERY impressed with the shear pin model Bush Hog Squealer.
If I were you, I would get the Bush Hog. But from what I hear, both are excellent cutters.
Travis
2015 FREIGHTLINER (A50323)
2015 FREIGHTLINER...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
John Deere L125H Skidloader (RUNS) (A50774)
John Deere L125H...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
2021 TAKEUCHI TL12V2 SKID STEER (A51242)
2021 TAKEUCHI...
