rotary cutter rebuild
   / rotary cutter rebuild #1
MESSMAKER
Bluegrass,KY
DK4710SE
I ended up with a Big Bee 5' rotary cutter(ld 540 I believe) as part of a deal. I have decided to keep it as a spare. It has a new gearbox on it and the sides are fine,The trailing wheel is OK, but not HD by any means. but the A-frame is bent slightly and the sheet metal is rusting. My neighbor and I are going to replace the sheeting with some 3/16 S. M. that we have laying around. I have access to torch, welder and a good bit of almost fee metal. What other improvements should I consider?
   / rotary cutter rebuild #2
How's the blades? Are you going to have photos of the mower and the rebuild. I have one that could use the deck replaced, would be nice to see yours done. ;)
I have already started on it. The blades are good but not great. I put a down and dirty paint jop on it yesterday. I changed it from rust and red to black.I took it out for a trial run and it works just fine. I will try to get a photo or two up.
   / rotary cutter rebuild #4
Sounds good but if you didnt already you might want to sharpen the blade.:thumbsup:
I keep the blade on my good cutter sharp, but to tell the truth, I can't tell much difference. It may not bog down as easily, but the cut looks about the same.
[/IMG]
This is what I am starting with.
   / rotary cutter rebuild #7
I don't use the top link for my mowers... If I have to raise it up, using just the wheel in the back and the bottom lift arms will raise it high enough to get over any rocks. I basically I just drag the mower behind me with the lower arms.
Compared to mine... that one looks good :D It looks like the top part of the 3ph moves in and out? (since the chain and the bent section)
   / rotary cutter rebuild #8
Unless there are some structural integrity problems with the deck that create a safety issue, I'm not sure I'd invest the time and labor in replacing the deck with new metal. It's doubtful that it will increase the resale value.
Hard to see in the photo, but the sheet metal has about 500 small holes in it. I am a bit worried that it might not hold back dome debris that shoots out just right. I do some contract mowing, so I plan on using this as a back up unit and really don't look to sell.
   / rotary cutter rebuild #10
if you are re-skinning.. don't overlay.. it will rust out. torch out the old metal leaving a lip to weld to.. be better off that way.
soundguy
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
2018 TAKEUCHI TB240 EXCAVATOR (A51242)
2018 TAKEUCHI...
