Rotary Cutter Rotary cutter question
/ Rotary cutter question #1
rims421
Eastern CT
new holland tc- 35
I have a howse 5' medium duty cutter with a slip clutch.
It seems that the blade tends to slip to easily when cutting heavy brush (clumps 3/4" to 1"). Is this normal? How easily should the clutch slip? Is there an adjustment on the slip clutch and if so how do you adjust it. I did not recieve an owners manual with the cutter. Any help from the "Tractor Gods" would be great.
/ Rotary cutter question #2
</font><font color="blue" class="small">( Is there an adjustment on the slip clutch and if so how do you adjust it. )</font>
Yes, it's adjustabe. I'd suggest you go to http://www.bushhog.com, click on the downloadable manuals, go to the manual for the Squealer series rotary cutters, page 12, for the illustrated instructions. Other brands and models may not be exactly the same, but the basic adjustment procedure should be.
/ Rotary cutter question #4
That's even better, Bill; color pictures. /forums/images/graemlins/laugh.gif
/ Rotary cutter question #5
Sounds like you are slipping a bit too easilly... I would want a slip to start in a situation the cutter was going to have problems with.. like slipping at 2" and up.
Not sure what kind of slip clutch you have.. but there should be a ring of spring loaded bolts around the circumference.. these controll the slip friction.
Too much slip and you will burn the clutch up.. Also.. you need to watch out for the plates sticking. Many people remove thier clutch from the implement and bring it in the barn so it doesn't rust up. There are also slip compunds available to treat the plates.. TSC and such places sell it.
Soundguy
/ Rotary cutter question #6
</font><font color="blue" class="small">( color pictures. /forums/images/graemlins/laugh.gif )</font>
I miss JohnMiller3's picture gallery. Does anyone know why he quit participating in the forum? I notice that he's still listed as a Moderator, but his last post was over 6 months ago. /forums/images/graemlins/confused.gif
/ Rotary cutter question #7
Well.. since he's 'ascended'* why would he want to muddle in our 'mortal' affairs unless he has to. /forums/images/graemlins/wink.gif
Soundguy
* in reference to Stargate SG-1 tv series re: Daniel Jackson..etc
Thanks for all your help .
When this snowstorm ends I will play around with the adjustment a bit. Do you guys think the slip clutch is the way to go instead of a shearpin? I think I might have smoked the clutch pretty good. How long do they normally last? I have used it for approx. 3-4 hours. I had to constantly raise the deck up to get the blade spinning then lower it back down onto the heavier brush.
/ Rotary cutter question #9
The only way to go. Just think of the time you would have spent changing bolts. Shear bolt drives should be limited, or an option and slip clutches standard. Maintenance is limited to once a year, for about 20 minutes.
/ Rotary cutter question #10
It seems to me that the majority of the forum members prefer the slip clutch, and I suppose if you have a lot of rocks it's the best way to go, but I never had one myself. All my implements had shear bolts, I kept spares on hand, and never sheared one. The only shear bolt I ever had break was on a neighbor's round hay baler. It seemed to me that all the implement dealers in my area priced slip clutches about the same; about a $100 option. I know a farmer neighbor with big tractors hired me to till his garden. He had rented a tiller once and it wouldn't work so he returned it and got his money back. And when I asked and he described what it did, I know that it had a slip clutch that was either worn out or adjusted so loose that it couldn't turn the tines in the ground.
/ Rotary cutter question #11
Howse did use a unique clutch, in that it had a big (maybe 2 inch diameter) slotted nut on the gearbox side of the clutch and in that nut they had a set screw that had to be backed off before using a punch or chisel with hammer to adjust the clutch tension--Check and see--I am not sure if the have changed to the multibolt pattern that is adjusted from the front--We probably have the slip discs from old stock, if you need them?--Ken Sweet
Sweet Farm Equipment LLC *Refurbished Cultipackers, Sickle Mowers and 2 Bottom Plows*
/ Rotary cutter question #12
<font color="blue"> I kept spares on hand, and never sheared one </font>
The BushHog Squealer I have has a shear pin. When first shopping for a cutter, I wanted one with a slip clutch, but in a very uncharacteristic move (for me), I decided to go the cheaper route. I figured I would be changing shear pins often, but like you, Bird, I've never had one shear, despite hitting my fair share of potential disasters. Of course, my tractor is on the puny side of the recommended HP range. S'ppose that could have something to do with it.
OkieG
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
Pallet Racking (A65640)
Pallet Racking...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
Bobcat SC72 (A64127)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Ingersoll Rand Roller (A64553)
Ingersoll Rand...
