Rotary Cutter Rotary cutter PTO hp
   / Rotary cutter PTO hp #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
Is there a rule of thumb to apply to required PTO hp for a rotary cutter? I used to have a 60" King Kutter that I used with a 20 PTO hp Cub Cadet (gear drive). It seemed to work fine. Now I have a JD 2520 with 20.5 PTO hp but it's Hydro drive , and I'm wondering if I could still get away with a 60" cutter. Just cut'n weeds and small 1" saplings.
   / Rotary cutter PTO hp #2
Mornin Ron,
I would think you can still get away with it. On occassion you may have to take a slightly smaller cut but shouldnt be a problem. I use a 5ft on my MF-1040 32HP diesel with 28PTO HP and at times I wish I had a 6ft but not willing to spend the money :)
   / Rotary cutter PTO hp #3
Conventional wisdom seems to agree that - for general duty applications - 5 or more PTO horsepower per foot of swath is recommended when selecting rotary cutters.
Sounds like what you're doing would be considered light duty, so you can likely get by with 4hp/foot. But if notice thick patches have a tendency to slow you down, or need a second pass to finish cutting........maybe not. I had a 5 footer behind a 21.5 PTO hp Jinma (4.3hp/foot), and found myself going back over too much ground. I've now got a six footer behind a 39 PTO hp KAMA (6.5hp/foot), and am much happier with the results.
//greg//
I just found a Bush Hog Razorback model . It weighs 450 lbs and uses 3/8" thick blades instead of 1/2". Much lighter duty.
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A54811)
Miller Trailblazer...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
2016 Ford Expedition XLT 4WD SUV (A55853)
2016 Ford...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
