Rotary Cutter Rotary cutter not cutting.
   / Rotary cutter not cutting. #11
I just sort of scanned the other posts, I didn't see anyone suggest anything about belts slipping. I had an old Ford pull type mower that had a gear box in the middle but the blades ran off of belts. It would work great until the belts wore and got slick, then it would develop the symtoms you described. If the blades are gear driven, disregard this and forget I'm talking.
I wouldn't swear they weren't belt driven but I don't think so. Its a single spindle mower and the blade shaft comes out of the bottom of the gearbox. But something slipping is definitely the feeling I get.
Will investigate this weekend.
   / Rotary cutter not cutting. #13
Hmmm... If it only has a single spindle I would say no to belt driven. The Ford we had (100" cut) was more like a big finish mower (it had 2 sets of blades) than an actual bush hog, but it would shred some pretty big stuff behind a stout tractor.
Does it vibrate or do anything else weird, other than slip? The teeth could be gone or a key shaved on a gear/shaft assembly.
No unusual vibration. Less than normal in fact. Probably becasue the blades aren't reaching speed. Doubt major gear damage unless someone else used it after I did. It is more like something has come loose somewhere rather than broken.
I'll let you guys know the mystery next weekend.
   / Rotary cutter not cutting. #15
I had that problem on my old Gyro84. It was split pin worn out and allowed output piniom nut to back off. Happens with 50 year old equip sometimes. Don't run in that condition or gears will be gone.
   / Rotary cutter not cutting. #16
<font color="blue">Is there any other type of clutch? And if there was a shear pin that was sheared, would the blades spin at all?
</font>
Try checking the brush hogs output shaft as it goes into the blade carrier. The splines may be rounded out. There could be a key sheared on the input gear inside the gearbox--Ken Sweet
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A57024)
GMC 3500 Extended...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A55301)
DeeZee Crossover...
2016 Chevrolet Traverse LT SUV (A55853)
2016 Chevrolet...
23311 (A51694)
23311 (A51694)
