ArmsOutWide
I have a new Rhino 172 rotary cutter.  I bought it with the tractor and it came already attached to the 3pt / pto. I'm a complete tractor newbie and I haven't even learned how to remove/attach it yet (the dealer did install a quick hitch for me, so I hear that it will help tremendously).
I'm going to typically use it ~ 1-2 hours at a time, working about 8-10 hours total over a couple of weeks to mow my property. I'll probably repeat that scenario 4-5 times per year (so ~30-50 hours / year total mowing).
I have a lot of oak saplings (1"-1 1/2") to knock down the first time through, and I have tons of rocks, although they are relatively soft (sandstone). I do know that the cutter has a slip clutch, although I'd be hard pressed to tell you what one looks like at this point.
So, I've been reading my manual, and a bunch of old posts, and I'm just as confused as when I started. I think I have a list of questions though.
Given my usage patterns, how often should I (in days / weeks / months / tractor hours / cutter hours / whatever unit is best):
1) Check / replace the gearbox oil
2) Check / replace the blades
3) Do that re-adjust the slip clutch thing that sounds so complicated (I've already scalped a couple rocks, and got a puff of smoke out of the clutch ... at least I think that's what happened ... which sounds like a good thing based on what I've read so far)
4) Perform any other maintenance checks / adjustments that I'm not experienced enough to know to mention
Can I be certain that the dealer attached the thing correctly the first time? I've taken it out for ~ 1 1/2 hours and it SEEMS to be fine (grass knocked down, trees chewed up, rock collisions survived, etc). However, the deck doesn't seem to raise up until I hit a 6 out of 8 on the 3pt position control lever. Someone mentioned in another thread that I probably needed to adjust the top link, so I'll try that out as soon as I get the chance. It also goes down really fast (and hits pretty hard). Is that just a gravity thing?
Finally, the manual also talks about checking driveline lengths and hights and cutting stuff to fit, etc. Are those common tasks / problems?
Thanks in advance for the education. Hopefully I'll be a fast learner.
