Rotary cutter for M7040?
   / Rotary cutter for M7040? #31
The LandPride RCR1872 I had in mind has a 65 hp gearbox. Just enough so that it is above the 62 PTO hp of the M7040. Typically I like a bit more margin of safety but given what my pasture is like I suspect that only a 5% margin of safety is fine.
What were the other economy minded cutters you had in mind.
The more popular "premium priced" companies that have been around the block usually are very conservative in their gearbox ratings. Its the newcomers and off brands that like to exaggerate on paper to make their models seem more competitive and a better bang for your dollar than they really are. Land Pride, Bush Hog, and a couple others are usually on the conservative side.
   / Rotary cutter for M7040? #32
I think yall are both over thinking this. You will absolutely not cause any long term harm to your tractor by using it at less than capacity. A 6' cutter will work just fine behind a 7040 if that is what you want. Just get one with at least a 65-75hp gear box and don't worry about it.
This is the most important thing to consider damage to, the gear box. Running a brush mower is not going to tax the tractor engine until you hit the tall thick stuff. If you were running through tall thick stuff that would be a different matter all together and I am sure you would be addressing that instead. Just remember Engine HP is always more than PTO HP.
Yes with a wider platform you would be able to get just a little closer to a fence in theory or would you? If the implement width is within inches of the tractor width I don't see any difference unless your axle sticks out further than the edge of the tractor tire. Doubt the neighbors would see any difference.
Is the 7040 a cat 1 or a cat 2 3pt hitch? Just curious.
Now that you have mentioned that, I've wondered what it means when the specs say CAT 1/2. This is the case on the GL5x40, M5040,6040 and 7040.
I've interpreted this as I can run either cat 1 or 2 equipment but know that there is a difference in pin width of the links. I wonder if this means that bushings are required to convert cat 1 equipment I might have to the cat 2 size so that there isn't any 'play'.
Both the blower and the rotary cutter I am looking at (RCR1872) also list that they are cat 1/2 so I wonder if they come with bushings.
   / Rotary cutter for M7040? #34
   / Rotary cutter for M7040? #35
The M7040 comes with a Cat 2 hitch. Of course, it can be bushed to a Cat 1 for less than $10 in bushings from Tractor Supply or any tractor dealer. The way the lower arms are set up there is no excessive play.
Cat 2 implements are heavier duty and thus quite a bit pricier. Almost impossible to find on Craigslist, too.
My LandPride mower was listed as a Cat1/2. It came with a special "two sized" pin that could be used for Cat 1 or Cat 2. Other implements sometimes come with two holes if it is a clevis-style hook up.
The implement can be offset a bit by using the sliding lower arms on the M7040 - lengthening one and shortening the other. The attachment comes out a bit crooked-looking but it cuts the same.
   / Rotary cutter for M7040? #36
On a Kubota, pull the stabilizer pins, push the mower to the side you want, reinsert the pins with the holes. With a 5 ft mower, I can get 6" past my R4's on a L5030 that is set with the tires 6 ft wide.
On my MF, it doesn't have pins, you screw the opposite stabilizer out to push the mower sideways on the hitch.
This might be a silly question but how does one go about offsetting the hitch? I'm going to feel silly if this is is a trick that I should have been doing all along with my current rig which has a 5' cutter and 5' tire width.
   / Rotary cutter for M7040? #37
Run all kinds of Cat 1 stuff on Cat 2 tractors, have never used a bushing. Makes hooking up much easier too. Mowers, rakes, 2 furrow plow, post hole digger etc, all Cat 1 stuff.
The only thing is on my 100 hp tractor, its a true cat 2 and you can't get the posthole digger on it. Works fine on all the 50-70 hp cat 2 tractors so far.
Glad we got into this cat1/cat2 stuff.
I currently run the Pat's hook system. I was going to move them over to my new/old MF 255 and purchase a LandPride QH for the M7040.
Anyone for-see any problem with this? I figured the LandPride QH could be bushed if necessary to Cat2 and everything from that point on is Cat 1.
Comments?
   / Rotary cutter for M7040? #39
Comments?
The dimensions of cat 1 and cat 2 are different. You are not going to get a cat 1 quick hitch and use it on a cat 2 implement just as a cat 2 QH will not work on cat 1 implements.
I should be able to get a Cat 1 QH, use bushings so that it fits on my Cat 2 3PT and then hook up to Cat 1 equipment correct?
Everything I've got is Cat 1 and the new stuff I am getting is labelled as Cat 1/2. I suspect as a result what I want is a Cat 1 QH hooked to my tractor.
Year: 2016 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A51692)
Year: 2016 Make...
2022 Polaris Ranger Utility Cart (A50322)
2022 Polaris...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2010 Nissan Rogue SUV (A50324)
2010 Nissan Rogue...
2022 John Deere 6135E (A50120)
2022 John Deere...
Deere 9970 Cotton Picker (A52748)
Deere 9970 Cotton...
