Rotary Cutter for L3830
   / Rotary Cutter for L3830 #1
Kytractor
Eastern Kentucky
March 2012 new L45--John Deere 650 sold/Kubota M59 TLB/sold bx24 and L3830
Still trying to decide on a rotary cutter for my L3830. I have looked at the woods bb72 around 700lbs and bush hog sq 72 arouind 650 Lbs. A Kubota dealer that sells both said the bush hog sq 72 would be better because the woods has more of its weight toward the back. Well the manual says it can handle up to 926Lbs. which in that case it should handle the bush hog 286 which is 922 Lbs. /forums/images/graemlins/confused.gif I thought the woods hb 72 box blade would be to much, until I pulled it in med. up my 900 ft. drive which is pretty steep. I started pulling it down hill at first and then got a little curious and couldn't believe it. What kind of rotary cutters are some of you Grand L 3830 or similar tractor owners pulling now? Thanks for any input.---Shane
   / Rotary Cutter for L3830 #2
Re: Rotary Cutter for L3830
I have the bb72 w/ the l3830hst and it works great.....handles
well
   / Rotary Cutter for L3830 #4
Neil,
Which tractor are you pulling that landpride with? The Kubota or the Unimog?
Don't remember if you have PTOs on that mog or not... /forums/images/graemlins/smile.gif
   / Rotary Cutter for L3830 #5
Landpride 84" finish mower and a Woods DO 80, a 80" offset brush beast mower. It weighs 1300 lbs, but that weight is pretty much all on the ground all the time.
Scott, Are you mowing mostly flat land or hills? Does the front end seem light if going up a hill? Thanks, ---Shane
RaT, I would have to bring it up a pretty steep drive once in a while and would probably have to lift it some. Any recomendations? Thanks, ---Shane
   / Rotary Cutter for L3830 #8
My Landpride mower which is about all that ever gets used anymore weighs just about 800 lbs. Even with the loader off, going up hills is never a problem. For your needs, try your mower off the ground up the steep hills but don't raise it very much. Climb your hill and prepare to drop the mower if necessary if the front comes off the ground. If your under the weight limit Kubota recommneds, you should be fine. I'm sure the weight rating is all about the geometry of the tractor as obviously, the L3830 can lift far greater weights then the manual states for implement maximum weight. Even the Kubota brochure shows the L3130 pulling a batwing which will not be lifted by the 3 ph hitch and therefore not fall under the restriction they advise. For your needs, go with at least a 72" brush mower and be in the approximate range they recommend especially with the loader off. If the loader is on, your going to easily be able to lift anymower in the 72" range safely. I am more impressed with my little L3830 HST everytime I use it. I know my mowing speed has increased and the ability to trim closer and do less string trimming has been fantastic, in fact, my string trimmer has yet to be started this season although its time to get it out. Rat...
Thanks, Couldn't agree more about the L3830. After reading a few post about some tractors bogging down with thier box blades I was leary about going with a med duty until I pulled it with a full load (gravel and dirt) with teeth down up my hill. Maby the scarifiers was not down enough but it still impressed the heck /forums/images/graemlins/smile.gif out of me. ---Shane
   / Rotary Cutter for L3830 #10
I am using a 72" Howse cutter. My 3830 has yet to struggle with it. I have gone up and down hills with no problems what so ever. The 3830 has plenty of power to spare when pulling this rotary cutter.
buckle
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52141)
2016 FORD F550...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A50322)
2018 Toro Z-Master...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
