Rotary Cutter rotary cutter for L 5740
   / rotary cutter for L 5740 #1
DonatiD
Burgettstown, p.a.
Kubota l 5720
I have fields that are over grown ,no trees looking for the right size for my l5740
   / rotary cutter for L 5740 #2
:welcome:
To the TBN forum. We are glad that you joined us here.
With your 50 hp PTO, you can run any cutter rated for your HP. If the grass is fairly tall you will just have to take it a little slower. Also the larger the cutter, the slower you will have to go. You should be able to handle a 72' cutter easily.
   / rotary cutter for L 5740 #3
I have a similar sized tractor(L4240 HSTC) and purchased a 6ft.Landpride.Use it quite a bit and it is a good fit.7ft.er's are crazy expensive and if you want wider I would look at a 8ft.twin spindle.
   / rotary cutter for L 5740 #4
Just how big is this field?
I run a 8' twin behind my MX5100. Which is rated to lift less, and less power, but same basic frame/platform.
Don't take the comments "you should be able to run a 72" cutter" as meaning it's borderline. Because that's how I read it weather it was intended that way or not.
6' would be the MINIMUM I would want.
That said, back to the acreage question. An 8' twin cost about double a 6' if shopping new med duty. And in the used market, 8' twins you rarely see if ever, 6'....much more easy to come by.
If you have small acreage, like 5-6 acres, I'm not sure one can justify the added cost of the 8' mower.
Bit if you have 15-20 acres that you are going to be mowing with any regularity, I'd look for an 8' twin. And if hauling it around on a trailer isn't going to happen, I'd even be inclined to look for a pull type 10' mower
   / rotary cutter for L 5740 #5
I guess I said it wrong with the 72" statement. I was meaning 72" to start at as earlier I stated any cutter rated at 50 hp and above.
   / rotary cutter for L 5740 #6
It gets down to your budget. You can pull an 8 footer but it's going to cost you more than double a single gearbox 6 footer. I'm looking for a 10 footer now.
   / rotary cutter for L 5740 #7
Pull type 10' - Kodiak or a Mahindra stamped by Kodiak.
idaho2
   / rotary cutter for L 5740 #8
My previous 5240 and current 5460 both pull a 6 foot heavy duty Kodiak with no strain. You can easily pill a 6 foot cutter or bigger if you have the need. Jim
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
Kinze 2600 16 x 31 Row Planter (A52349)
Kinze 2600 16 x 31...
KJ Double Ply Polyester Webbing Sling (A50121)
KJ Double Ply...
2015 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A50323)
2015 Chevrolet...
New LS170 Skidloader (RUNS) (A50774)
New LS170...
