Rotary Cutter ROTARY CUTTER FOR FOOD PLOTS
   / ROTARY CUTTER FOR FOOD PLOTS
Thanks for the voices of experience. After bush hogging a field of brush, you leave a field of stubble, many of which are still rooted in the ground.
Would discing loosen these up enough to rake out or would you have to chisel plow running fairly shallow before raking. Trying to decide what implements we will need to buy to make all this happen as efficiently as possible, keeping in mind the budget constraints.
   / ROTARY CUTTER FOR FOOD PLOTS #12
A garden disc won't do what you want unless it's briars and weeds- stuff under an inch. You may scratch surface enough to plant some rye grass or clover, but not much penetration.
A disc plow will turn over small stuff 2-4" and not hang up on stuff it can't handle. I've never seen a CUT pull one though.
A turning plow will probably stay tripped and cause a bunch of ventures off the tractor to plow.
You might pull a cut down chisel plow or ripper, but you'll most likely stay hung up as I read that this is a clearcut and round here that means stumps with big roots aplenty under the small brush.
There's an attachment for fel that yanks small trees and brush up by roots that I can't remember name of.
Best bet is to find log sets and haul roads without large stumps and place plots there. They are usually highly compacted and need a deep workover to do well though.
   / ROTARY CUTTER FOR FOOD PLOTS #13
</font><font color="blue" class="small">( Thanks for the voices of experience. After bush hogging a field of brush, you leave a field of stubble, many of which are still rooted in the ground.
Would discing loosen these up enough to rake out or would you have to chisel plow running fairly shallow before raking. Trying to decide what implements we will need to buy to make all this happen as efficiently as possible, keeping in mind the budget constraints. )</font>
If you really want to do this on a budget, just keep it mowed. The stubble will eventually rot. This may take a couple of years. I've got a couple acres of pasture which were fairly densly overgrown with 1" saplings (and a couple larger). Repeated mowings have turned it into a field of grass/clover (it was a pasture years before I bought the land). After 1 year, it was still pretty rough. Now (4 years later) you are hard pressed to find any of the old 1" stumps. This area does tend to be on the wet side, so that may have helped the rotting process along...
The real trick with this is how to seed it to something you want. I did not need to seed it... the grass/clover came in naturally. But if you do need to seed, you'f probably want to scrape things up a but. You could try the scarifiers on a box blade (I happen to own a boxblade, so I may be suffering from the old saying: "when the only tool you have is a hammer, every problem looks like a nail"). Another alternative would be to try to rototill it. A a 3 pt hitch rototiller can be expensive to buy, but you can generally rent them.
John Mc
   / ROTARY CUTTER FOR FOOD PLOTS #14
I'll second the scarifiers on the box blade. I haven't run into any stubble left by the cutter that the box blade wouldn't pull up. It takes a few passes as the small root balls can pass between the scarifiers. After that a landscape rake is handy in rounding up the debris if you're not plowing it under.
The great thing about this site is that the more I learn, the more questions pop up!!! Fortunately when we initially clearcut the plots, we had a dozer clear the trees and stumps, so we don't have any big stuff to uproot. Although the stump craters have filled in some over the years, many are still localized depressions which should be filled in/smoothed out to effectively work prior to planting. Would the box blade with scarifiers work for that purpose?
   / ROTARY CUTTER FOR FOOD PLOTS #16
Yes, smoothing is the primary use of the box blade. It does take some practice to use it efficiently, but there has been a lot of advice posted on this site explaining how its done. This thread is a good place to start.
   / ROTARY CUTTER FOR FOOD PLOTS #17
The boxblade is the tool of choice for that. Better is the dozer but that is only if you have a dozer on hand.
   / ROTARY CUTTER FOR FOOD PLOTS #18
I did exactly what you have done. Started with the DR mower, wore myself out on the weekends, then got smart and bought a 25 HP Yanmar and 4' bush hog. Eats anything the tractor can run over. I have mowed 5 year old clear cut sections, no problem. I don't have a FEl either, just good eyes and a slow throttle!
   / ROTARY CUTTER FOR FOOD PLOTS #19
Get an old bog harrow and you can cut the soil enough to create a bed to plant. I bought an old rusty one for $100 off the side of the road, works great for food plot mixtures.
Mother nature just dumped a foot of snow on us. I was planning to hunt this PM and tomorrow--deer should be out feeding after the storm. Don't know if I can even get into camp. Those darn township plows create huge windrows of snow at the driveway entrance. Sure could use a tractor with FEL now to dig my way in. Now would be the perfect time to hunt around plot of brassica or sugar beets I guess. Wish me luck.
2014 Chevrolet Traverse 2LT SUV (A55853)
2014 Chevrolet...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2016 Ford F-250 4x4 Reading Service Truck (A55852)
2016 Ford F-250...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
