rotary cutter for bx23
   / rotary cutter for bx23 #1
hospitaldoc
Farmington, Maine
Kubota bx23
I apologize for any redundancy but I have checked the archives and found more confusion than answers. I am considering buying a rotary cutter for my bx23. It would me used mainly for cutting unruly fields that are neglected and overgrown. Very little if any saplings/thick brush.
What would you guys recommend and what are the going rates for one? Unfortunately there appears to be quite a shortage of used ones up here in Maine.
Larry
   / rotary cutter for bx23 #2
I would go for a 4 ft. model at a weight of 400-500 lbs. This would be considered medium duty by some manufacturers, others might call it light duty or standard duty. I have a Fred Cain Agri-Cutter AC-104 for my BX22. It is a 4ft model, weighs in right at 500 lbs. It is a great match for the BX. I always have the loader on when using it as it might be heavy without the weight on the front. I would think most manufacturers would make a similar cutter e.g. Woods, Bush Hog, Land Pride. I'd guess you are looking at $400 - $600 depending on which brand and whether the prices in your area tend to run high or low.
Hope this helps!
Terry
   / rotary cutter for bx23 #3
I have been looking them lately and the 4ft King Kutter at the local Tractor supply is running right at 700 bucks Here in Indiana Lately I have been borrowing a 4ft John Deer and it works well with my BX23
   / rotary cutter for bx23 #4
Update: I just saw a FC Agri-Cutter listed on ebay for $695, so maybe they are a little higher than I thought. I purchased mine 4 years ago for less than $500.
Terry
   / rotary cutter for bx23 #5
I have a Bush Hog Squealer 48" that I would recommend but am sure there are others just as good. I highly recommend getting the tail wheel, front rubber flap guard and the rear steel guard (if applicable).
   / rotary cutter for bx23 #6
For what you describe, I'd agree with Medium Duty 48". I have a Gearmore Heavy Duty 40" on my BX2200. It will cut very thich and heavy brush, up to 2" saplings.
   / rotary cutter for bx23 #7
Does anyone make a 48" unit with a slip clutch instead of shear pins? If so, any idea on the price?
I was quoted$1200 for a 4 foot rotary cutter by Woods with a slip clutch at a local dealer here in Maine
   / rotary cutter for bx23 #9
Wow, $1200 seems a bit much for a 4ft cutter! JMHO! For those $$, I would get a $700 med duty cutter (similar to mine as described above in this thread), add a landscape rake, rear blade, or other needed implement. You stated most of the cutting is grass, so you should be fine without a slip clutch. Cut the grass high at first, walk the property looking for obstructions, rocks, logs, etc. Once you are sure you won't hit any major obstacles, cut it lower and no need for clutch. Again, JMHO!
Terry
   / rotary cutter for bx23 #10
Here in Pa.it seems if you shop around a little there are quite a few good used 4ft cutters to be had.For the most part they are not over used,seems like a lot of people purchase one then find out they just don't have the use for it.Some trade them in for another pc of equipment or sell them out right.About 4 months ago I purchased a used Landpride RC 1548 it was in almost new condition for $450. Like was said before a rear gauge wheel and front gaurd are a must.For you sub compact make sure it has 2 sets of holes for arm pins or you will have a hard time lifting it of the ground.For the BX series you need the lower pin hole's,and will most likely have to shorten your pto shaft some,unless you purchase one that is made for a sub compact.Good luck, take your time shopping get what will work on your tractor and do what you want.Ask a lot of questions at dealer's they should be happy to answer them,if not find another
2014 Homemade 16' Gooseneck (A50121)
2014 Homemade 16'...
Case IH 140 Maxxum (A50120)
Case IH 140 Maxxum...
2017 John Deere 6120E 120HP 4WD Agricultural Tractor (A50322)
2017 John Deere...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
