Box Scraper Rotary Cutter & Box Blade Questions
   / Rotary Cutter & Box Blade Questions #21
greg_g said:
Now you're getting way too complicated, and foolish if you believe that 10hp bit. I'm going to bow out now, because I believe your decision to widen the track to operate on hillsides you've never even driven on yet, has compromised the ability to match implements to horsepower.
//greg//
Thank you. Everything you say makes perfect sense. However both Kubota dealer and Ford dealer recommended turning tires after visiting property. As I bought tractor in Alabama it was impossible to transport home to test as I felt it more imperative to have Ford-New Holland dealer check it out. I do appreciate you taking the time to respond.
   / Rotary Cutter & Box Blade Questions #23
No problem. It's just that I'm only 120 miles NW of you, so I know the lay of the land. I'm pretty sure my WKY river bluffs are no less steep that what you have around Auburntown. I've adjusted my front/rear track widths to be equal - been that way for years - and I just can't see a situation where such a front/rear disparity such as yours would be any advantage (without duals that is).
Going up/down hill there's absolutely no advantage whatsoever. Where the stability of width comes into play, is when you put yourself into a situation where you have to operate parallel to a significant grade. My equal front/rear track widths cope quite nicely with some of the 60% grades I have to work. Sideways.
Not telling you to be unsafe now, but I'm thinking that maybe you're just being a little over-cautious. And in doing so, have made it difficult to competently match implements to horsepower. Remember I said you want to cover your tracks, and a 9-10 foot mower is a lot for 45 PTO hp. Same with a box blade. You'd need no less than an 8 footer, in which a full load is capable of stalling 50 engine hp. And the list goes on.
//greg//
   / Rotary Cutter & Box Blade Questions #24
Maybe I should read more carefully. If your going to operate on steep inclines I would be very careful. I have a 33 horse tractor and it can run a 6 foot brush cutter. However, I mow a very steep pond bank so I use a 4 foot mower to keep from being pushed with weight of the mower. As to the 10 HP because of the front wheels being able to pull that is just a thing that goes around here. No scientific data there.
I do know this that it most certainly gives much better pulling power because all wheels are pulling. I have had the thing spin the rear wheels on a very gentle slope, put it in FWD and it goes right along.
As I stated if you haven't had a lot of experience BE VERY CAREFUL on slopes.
   / Rotary Cutter & Box Blade Questions #25
//greg//
Whoa! Dude, you must clank when you walk having b---s that big! I about wet my pants on anything over 25-30%. Especially when hitting a hole, rock or other thing that quickly changes the tilt. Had to iron out the pucker nucker from the seat a couple times too.
jb
   / Rotary Cutter & Box Blade Questions #26
You might be confusing angle with slope. It's a trig thing. Flat = no slope, 45 degrees = 100% slope. A 30 degree hillside therefore represents a 58% slope. Some of the rightaway I mow is steeper than 30 degrees, therefore at least a 60% slope. If in fact you have them reversed, a 22.5 degree angle represents a 50% slope.
//greg//
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2020 PETERBILT 567 SLEEPER TRUCK (A56138)
2020 PETERBILT 567...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
2022 Case IH 8250 Axial-Flow Combine (A53485)
2022 Case IH 8250...
