Rotary Cutter rotary cutter advice
/ rotary cutter advice #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i'm finally dropping the ball and going w/ a jd 790 w/ 300 loader. the jd dealer has either jd or landpride attachments. i like the lp rotary a little bit better than the jd. i was just looking for some thoughts on rotary cutters and where can i find the specs on them. i used to use my dads 6ft rhino rotary years ago, that cutter was a heavy duty model and had folding blades if you hit something. also wondering if they have changed since then. thanks in advance for any info.
/ rotary cutter advice #2
I've got a 790 and run a Land Pride 60" cutter. That's a great combo.
Land Pride has a pretty nice website and you can glean all the information you'll want about their cutters. I will tell you the 60" Land Pride weighs around 625 lbs, so you'll want the loader on as a counter balance.
I was going to buy a King Kutter cutter initially, but I couldn't find a 48" unit when I had my Deere 670. I didn't think the 670 (16 HP@ the PTO) could handle a 60" unit.
A local Kubota dealer sold Land Prides, so I went to check them out. Although they had no 48" cutters, they told me the 60" units were frequently used with Kubota B7500 which are about the same in power as the 670.
The 670/60" Land Pride worked great, much to my surprise. I was clearing brush that was thick and as tall as the cowl of the tractor...some taller.
The 790, with 8 more PTO HP, does operate easier (less bogging).
The Land Pride went for just over $1000 when i purchased it in the Spring of 2004. Although a "standard" duty cutter, it does a heck of a good job.
I think you'd be very happy with a 790/Land Pride cutter combination.
/ rotary cutter advice #3
Most/many rotary cutters are similar in design, and have a blade carrier or stump jumper that has blades attached to it that can pivot to avoid obstacles.. etc.
Both units you mention are top notch..
good luck
Soundguy
/ rotary cutter advice #5
Roy: I have a new JD 790 (which I've found to be a real work horse -- I love it). I'm now ready to add a rotary cutter for about 3 acres of pasture (some small rocks and sticks from the trees) and along my driveway, etc. You said you have a 60" Land Pride and are happy with it. Silly question, I suppose, but that measures beyond the tractor wheels, doesn't it? Any suggestions or cautions?
Thanks,
Susan
/ rotary cutter advice #6
Definitely use hearing protection of some sort. I use ear plugs, but some folks prefer the muff style.
Also, use your seat belt!!!!! That tractor will keep on going rather your in the seat or not. There is a "dead man" switch under the seat, should you fall off the tractor. However, I'm not depending on it. I just saw some pictures of a farmer ran over by his cutter after falling off his (older) tractor. This was just before responding to this post. Not a pretty sight as you can imagine!
Brush cutting is not a job to do if you're tired or worn down by the heat (it's going to be 95° here in PA today...and I probably will be doing some cutting).
3 acres is about the same as I maintain. If you haven't mowed that area yet, go slow for the initial mowing. I use 1st and 2nd gear low range since my acreage has several rutted areas hidden by the brush. It takes longer, of course...but safety first. Anyway, I'm just not in any hurry when operating the tractor.
If you have to transport that cutter in the raised position, make sure your lower link turnbuckles are tight enough to eliminate as much sway as possible. Definitely slow down for turns when transporting...that's a considerable amount of weight extended out back of the tractor!
Personally, I rarely transport the cutter in the fully raised position. I normally just raise the front of the cutter a bit (to prevent the side shields digging in) and tow it with the tail wheel taking most of the weight.
If you have a loader on your 790, I suggest you leave it on when brush cutting. The loader counter balances the cutter nicely and leaving the bucket low (slightly in the dump position) can help find and stumps, old fence posts or other things jutting up from the ground.
My 790 has never over heated. It normally runs pretty cool even when the radiator grill is clogged with dust and pollen. Obviously, you do want to keep an eye on your temp gage though.
The 790 does real well with a 60" cutter. Personally, I think a 60" cutter is perfect for the 790. Even with that first cutting (when the brush might be really thick and tall), the only thing you may have to do is make passes that aren't the full width of the cutter. No big deal there...and the next time you mow, you can run the full width. Common sense will dictate if you need to make partial passes.
When you get your cutter, there is a procedure to engage the PTO. Pretty simple...engage at 1200-1500 RPM with the transmission in neutral. If the tractor starts to stall, just blip the foot throttle. Release the clutch and let the cutter blades extend (you'll hear a couple thumps and feel some vibration). It'll take 5-10 seconds for those blades to spin up. Once that is done, increase your RPM to PTO speed (about 2600 RPM) and engage your transmission. Definitely use a low range gear! I strongly suggest 1st gear low until you feel comfortable. After that, just go do your work.
There's also a debate rather to use a rigid top link. The first time I cleared the arcreage, I did. This year I left the top link disconnected. The 790's rockshaft lever has an adjustable stop for the lowered position. Suggest you set that so the front of the cutter (judge this by the side skirts of the cutter) is a bit lower then the aft end of the cutter. As mentioned, my area is pretty rutty. I still scalp on occasion but I do a better job with the top link not connected. My only concern with leaving the top link off is if the cutter jumped up. The PTO shaft will only collapse so far, so I cannot see the aft end of the cutter lifting to much.
One more thing...cutters are some heavy beasts! Rigging them to your lower links involves a lot of levering (use a 2x4 about 60" long) and cursing. I bought the Pat's Easy change which does reduce much of the really aggravating work. Doesn't eliminate all the hassles, but makes life much easier. After you first rig the cutter to the stock lower links, you'll know exactly what I mean. You may even invent new nicknames for your tractor, rotary cutter and life in general.
Hope this helps! That 790 is a fine machine...fits any task a small farm or residential owner needs to do. I'm sure you'll enjoy operating it as much as I do operating mine.
/ rotary cutter advice #7
</font><font color="blue" class="small">( Brush cutting is not a job to do if you're tired or worn down by the heat (it's going to be 95° here in PA today...and I probably will be doing some cutting).
)</font>
I cut 10ac yesterday morning here in florida. I think it was 95' and humid!!
Soundguy
/ rotary cutter advice #8
Go get the Deere iMatch Quick Hitch, it will make your life a lot easier.
/ rotary cutter advice #9
I cut 10ac yesterday morning here in florida. I think it was 95' and humid!!)</font>
My worst day was 2 years ago at 115°. I spent 3 hr. with the rough cutter cutting bone dry Russian Star Thistle, which is poisonous. I couldn't find my respirator filter mask, but I went ahead anyway. My clothes, face, everything were covered with a layer of powdered dust of that stuff 1/4" thick. That was my first time to get chronic asthma. Took 2 months on inhalable steroids to get over it.
Sometimes, being macho is not the same as being smart.
/ rotary cutter advice #10
I agree. when I bought that pasture.. it was covered in dog fennel and ragweed 7' tall. I was a big puffy sneezing , red-watery-eyed SOB after mowing it. I'me one of those people that gets a sinus infection if i have a bad alergy attack.. so it was a bad move for me as well...
I now take a prescription antihistamine in the morning before i go out and tackle the tall grass.
Soundguy
/ rotary cutter advice #11
We sell the Agri 5 series by "Big Bee" with no reported problems. The 5 ft with shearpin, flexhitch,segmented tailwheel rubber, adjustable cutting heigth, stumpjumper, extra deck bracing and swinging blades sells for $695 + shipping and no sales tax--Ken Sweet
Email sweet@scrtc.com
/ rotary cutter advice #12
</font><font color="blue" class="small">( We sell the Agri 5 series by "Big Bee" with no reported problems. The 5 ft with shearpin, flexhitch,segmented tailwheel rubber, adjustable cutting heigth, stumpjumper, extra deck bracing and swinging blades sells for $695 + shipping and no sales tax--Ken Sweet
)</font>
How much for a 6 footer shipped to zip 30824? Trying to help a friend whose 6 footer is toast.
gabby
/ rotary cutter advice #13
His total cost, INCLUDING Basic shipping to a business/commercial 18 wheeler accessable address with a Unloading dock or forklift for unloading at that zip code, will be $979 on the New 6 ft Brush Hog ---NO SALES TAX --If you require Special Limited Access delivery,(This includes most Farms, Marinas, Golf Courses, Residential Homes, Military Base, Mines) that is 18 wheeler accessable, Please add $45 to the above shipping quote--Estimated shipping time is 2-3 working days--Coming mostly assembled and all new equipment comes with a manufacturers warranty aganist defects in material and workmanship--To Place hisr Order ANYTIME--Have him to Email sweet@scrtc.com or Call 270-528-3323-Mon-Fri and Sat 8-12 CST --Ken Sweet
/ rotary cutter advice #14
Ken,
Thanks for the quote and shipping info. What brand is it? How much does it weigh? What's the hp rating of the gearbox?
gabby
/ rotary cutter advice #15
Farmerjim - I may be overly cautious, but after getting hit a few times with flying debris, installed a screen on the back of the ROPS to intercept some of the junk that occasionally flies forward. Just a thought.
penokee /forums/images/graemlins/smile.gif
/ rotary cutter advice #16
One more picture.
2014 MACK PINNACLE DAYCAB (A59914)
2014 MACK PINNACLE...
King Kutter 7' Lift Kutter Rotary Mower (A66408)
King Kutter 7'...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2716SFL (A61567)
2716SFL (A61567)
