ROPS Raising?
/ ROPS Raising? #1
Mobass
Bronze Member
Lebanon, MO
Mahindra 8560
I have a 8560 that I have to put the ROPS down to park it under cover. The problem is putting it back up is a PITA. So any ideals or tips to make it simpler?????
/ ROPS Raising? #2
You know, the ROPS safety feature has been added for many years to protect a 'belted in' driver. It helps with rollover, and probably more importantly, keeping the tractor from back flipping on top of the operator. I have run tractors since I was a teenager [ I'm old and decrepit now ], and my new Mahindra is the first tractor that had a ROPS. And, while not real proud of the fact, I have never used the seat belt on it. What I am trying to say is, you can leave it down.... or even possibly modify the top section to lower the height some so you can leave it up. It's your tractor, and your call. Most tractor accidents are caused by people trying to pull something without using the drawbar, excessive speed when pulling, operating on too steep an incline, etc.... There is no law saying you can't cut the thing up for scrap..... My 5035 fits into my 10' roll up doors.....
/ ROPS Raising? #3
Loosen the lock nuts on the hinge bolts, and file the holes for the lock pins till the pin goes in and out easily.
/ ROPS Raising?
The real probem is trying to lift it back into place. I had to stand on the back of the lift to get leverage to lift it up. I am not a 90 pound weakling but it is hard to get good levarge on it. My farm is pretty hilly so I am very cautes in what I am doing. Pluss I like the ROPS up just for the added safty.
/ ROPS Raising? #6
The real probem is trying to lift it back in place. I had to stand on the back of the back lift to get leverage to lift it up. I am not a 90 pound weakling but it hard to get good levarge on it. My farm is pretty hilly so I am very cautes in what I am doing. Put I like the ROPS up just for the added safty.
I'd walk it up using a tall ladder to get better leverage.
/ ROPS Raising? #7
Does it swing freely? It sounds like the hinge bolts are tight, and if you loosen the bolt it is hinging on, it will get a lot easier.
/ ROPS Raising? #8
Maybe rig some stop up so it only allows the ROPS to swing backwards just enough to clear your structure. Then you would only have to push up a short distance to get it back in position. [ Fab up a block that attaches to your ROPS hinge bolts ]. Or put a taller door in your structure.....??? :)
/ ROPS Raising? #9
I am surprised someone hasn't already tried hooking a lift cylinder to a rear remote....or at least I thought I'd seen it all.
/ ROPS Raising?
thought crossed my mind...lol. The ROPS when lowered is still to high for me to touch when I am standing on the ground. I was thinking of a push stick maybe??? Next time you are around a 8560 you will see what I mean..
/ ROPS Raising? #11
Just a thought because someone mentioned using hydraulics. You could fasten a rope to the ROPS and attach it to the FEL when raised to upper limits and then use the FEL to pull up the ROPS. OR fasten a pulley and rope to the FEL bucket, raise it as high as it will go and use the rope and pulley to raise the ROPS while standing behind the tractor, then just pop in the pins.
/ ROPS Raising? #12
Try attaching a bar that is fixed to the upper section in a manner so that it extends lower then the hinge point by 12-18". When putting ROPS up you can apply pressure to extension bar for added leverage which should ease the uprighting process.
/ ROPS Raising? #13
Mobass, I think your push stick idea will work good if there is no binding, and the ROPS go up easy ( no binding). Screw some two bys together like a Y and just push it in place from the ground. :2cents:
/ ROPS Raising?
I think I will go with the push stick. Thanks for all the ideals.
2006 Chevrolet TrailBlazer SUV (A66738)
2006 Chevrolet...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2006 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2006 TROXELL 150...
40' 6 Door Shipping Container (A68183)
40' 6 Door...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
