ROPS paint?
/ ROPS paint? #1
gwstang
Platinum Member
Lake Martin Alabama
1952 Ford 8N / Kubota L2501
I need to get the grey colored spray paint can to touch up my rops on the L2501. Does anyone happen to know which spray paint will match up pretty close for the rops? Something from wally world maybe rustoleum? It's some sort of dark grey. Thanks. I did do a search but came up with many threads with rops and spray paint, and nothing about this. i couldn't figure out how to do the search and make it with rops and spray paint only in the thread.
/ ROPS paint? #2
I have seen Kubota Gray at tractor supply, so maybe check there. Of course, you can get an exact match from the dealer but it will be $$$.
/ ROPS paint? #4
Local Kubota dealer? Bought my orange and grey there. Beware there are two oranges. Don't know about grey.
/ ROPS paint? #5
There're two greys involved, also, depending on the age of the tractor. One is blue-ish, the other just grey. But being small area, you can fake it with something close. I sprayed some areas of my L3130's engine side panels with a close, but not perfect, match and once done, you had to know it about to even notice the lack of a perfect match. It was an off the shelf grey that looked close, not a specialty tractor paint.
/ ROPS paint? #6
I wasn't sure which of the two Kubota grays or is it grey? to buy, anyway I bought what's called rops grey to paint the rear wheel spacers on my B2601 and appears to be a perfect match but expensive, $15. As far as the orange paint, I have heard that Dupli-color's Chevy engine enamel is a good match but don't know if it's for the newer or the older Kubota's?
/ ROPS paint? #7
I use Rustoleum Charcoal grey, just a hair lighter color.I have a newer BX 2360 from 2012-2013.
/ ROPS paint? #8
The Rustoleum Charcoal Grey is close but hard to find, try hardware or tractor supply stores, big box around here do not have it. Also look for Van Sickle paint had a white color for another vintage brand that matches up good with the radiator support on earlier machines.
David
/ ROPS paint?
Thanks everyone. I stopped by the TSC today and the closest thing there was a MF gray.
/ ROPS paint? #13
Buy the Kubota spray paint. It's just a much better product. I messed around with several other brands and they work OK but when I made some brackets to mount some aux lights to I got Kubota paint. After using it I wouldn't go back to the other brands. It seams to cover better and is a lot more durable.
/ ROPS paint? #14
I was just thinking about posting basically what crazyal just posted. Don't know about the greys, but the Kubota orange is a fine rattle can product- and none of the aftermarket "matches" are near as good in terms of coverage and toughness, or color match and sheen, either.
/ ROPS paint? #15
It's true. The ones Kubota sells are plain old better. They are an acrylic based vs the alkyd that most cheap ones are. Much better coverage and durability. From reading it here and then personal experience.
Odyssey Pontoon (A62613)
Odyssey Pontoon...
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
2024 14ft Pairboat Flat Bottom Mud Boat (A61574)
2024 14ft Pairboat...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
