ROPS Light Install
/ ROPS Light Install #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
I recently added 4 lights and a strobe to my ROPS, and I thought I would share them with everybody.
The lights are 50 watt HOBBS Trapezoids purchased from Messicks
The Strobe was a "extra" one from work...
I also added a rear 12v outlet while I was in the wiring mood.
Yes, I drilled the ROPS /forums/images/graemlins/shocked.gif, I know the consequences of my actions, I am a big boy and can take the heat, No further comment is necessary /forums/images/graemlins/grin.gif
The first pics is of the 4 switch bezel's I installed in the left fender...
Second pic is of the 4 switches installed...
Front Lights
Rear Lights
Strobe
12V Outlet
Third pic...Lights, Rear View
Fourth Pic...Lights, Front View
Fifth and Final pic...12V Rear Outlet
Thanks to all who help inspire my ideas and cost me money!
/ ROPS Light Install #6
Kenny as always your projects are a class-act. Nice clean looking installation of lights. Now you can plow snow all night long. /forums/images/graemlins/grin.gif
/ ROPS Light Install #8
Great looking installation!
Where did you get the bezel and switches?
The bezel's and switches are from a marine store here locally, I think it was West Marine?
Thanks for the kind words...
/ ROPS Light Install #10
</font><font color="blue" class="small">( The Strobe was a "extra" one from work... )</font>
Strobe must have fallen off a phone truck!! /forums/images/graemlins/blush.gif Great job Kennyd!
/ ROPS Light Install #12
I have always been of the opinion that "extra" items should be put to good use. If you don't use them they will go bad. /forums/images/graemlins/grin.gif
Nice job, Alan
/ ROPS Light Install #13
kennyd ,
Nice work , I have looked at doing the same. Did you wire your lights through a relay or direct to the switch ?
Mark
Mark,
I used one 30 amp relay with a 30 amp circuit breaker to feed the new lights and the electric diverter I put on last year. This provides power to the 20 amp rated switches for the lights, witch in pairs draw just over 8 amps.
/ ROPS Light Install #15
kennyd ,
I have a 4110 not many good places to mount the relays and associated stuff. Where did you mount yours ? I do like the switch bezel and switches. I also saw them in west marine the other day xmas shopping.
Mark
/ ROPS Light Install #16
Good job. Do you have the higher amperage alternator then?
Ralph
</font><font color="blue" class="small">( kennyd ,
Mark )</font>
The relay is mounted under the fuse panel, there are some pics in this THREAD about my diverter install.
</font><font color="blue" class="small">( Good job. Do you have the higher amperage alternator then?
Ralph )</font>
Nope, here are my thoughts, The factory headlights are 55 watts, and JD gives you a hookup on one worklight.
I will not be using the new 50 watt front lights and the headlights at the same time, so I am save 10 watts there, So I figure I am only over the factory setup by about 3 amps or so...
Plus the alternator upgrade is $390.00 /forums/images/graemlins/shocked.gif and not even gold plated. If I burnt it up, I will try to have a local starter/alternator shop rebuild it, may with a little more juice /forums/images/graemlins/wink.gif
/ ROPS Light Install #19
Kennyd ,
Boy , Looks like you have done alot to your 4110. I am a bit ignorant when it comes to hydraulic plumbing /forums/images/graemlins/smile.gif , but I am getting a great education about it from reading posts like your on the diverter install etc. I hope you do not mind me asking a few more questions on the wiring for the lights. It was hard to tell from the picture of the 20A breaker , is that a self reset type ? Or a blade fuse type ? Also can you confirm that my understanding of how you wired the relay is correct.
Pin 30 = Power in from the breaker/fuse - 10 guage wire
Pin 85 = To Ground
Pin 86 = To ignition switch - On position
Pin 87 = To light switch on fender
The feed from pin 87 I assume you used for power in each on the switches on the fender ??
Instead of the seperate breaker / relay setup , I have a hella relay left over from another project that has a built in 15A replaceable blade fuse attached to the side of it. Would that be ok to use for 1 set of lights ? If so , could I swap the 15A fuse for a 30A and use it for 2 sets of lights.
I am current using the spare work light feed that JD provide on the back of the 4110 behind the seat. I'd like to add more lights /forums/images/graemlins/smile.gif
Again thanks in advanced for the help. I'd rather ask the right questions ahead of time ...
Mark
/ ROPS Light Install #20
<font color="blue"> If I burnt it up, I will try to have a local starter/alternator shop rebuild it, may with a little more juice </font>
Thought about doing this with my BX 23
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
1991 International 4900 Box Truck (A55315)
1991 International...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
40 (A52708)
40 (A52708)
