Roots in the septic tank
   / Roots in the septic tank #51
Sorry my brain is fried....I read loctite instead of locate. For some reason I was thinking you were going to put loctite on the threads after pulling the lid on the D Box. Carry on as if not here....haha
Hopefully you can enjoy the rain.
THAT is a good one. Yea I will, I have some "inside" projects to work on. Got a new (to us) quad the other day. $850 bought us a 1986 Honda 350 TRX 4WD, that the lister (a motorcycle shop) said was kick start only. I first verified it HAD an electric starter, it did. They had rebuilt the top end, rings, valves, and I can see the new gaskets. Runs excellent.
When I got it home I tore into the starter issue. After several hours of trouble shooting, I came to the unbelievable conclusion the starter was wired backwards. It had both a hot lead, from the solenoid, and a ground going to it. IT WAS SPINNING BACKWARDS :) . When I rewired it, it turns over perfect. :)
So now it's time for clean up and paint. Also need to fabricate a couple body panels cause replacements are absurdly priced. That is my indoor project.
It's used on the property, so I don't worry about looks a lot. So we now have 2 Honda quads, with under $900 in the 2 of them.
I am still debating on whether or not to tell the seller??????
   / Roots in the septic tank #53
I saw that post about the quad. What a deal. They were so frustrated they dumped it- great deal for you. I'd call them. I'm sure they would appreciate knowing.
Sounds like the septic fix is well underway.
Yea I just need some time for this muck to dry out so I can back fill. Problem is I cannot get my 5th wheel out either. It will sink in. I have to pull it out within 15ft of where the hole we dug up is. :eek:
Yea I already discussed that possibility with the wife. Most likely that will happen, I don't see this letting up too soon. The rain is stopped for today I think, but I see this coming Thurs-Sat it is back again. Feast or famine in this state with water.
   / Roots in the septic tank #57
Doesn't sound like you can buy enough rock to make a base with the rain you're getting. Might need to buy a pile of 3/4" plywood to put out to drive on!!
Yea I hope I can wait it out, time will tell. I just want it to dry enough to let me backfill!
   / Roots in the septic tank #59
How's this working out? Even though it's not covered has the tank and field been functioning properly?
This has not been a fun project. When we were lifting the tank lid, the neighbor had a light chain holding it up and trying to move it, the chain broke, and has cracked the lid in several places, it even cracked one of the access lids. It looked like they were fairly light cracks so I sealed them with mastic and a layer of strechable tar over that. I had the tank completely covered back up, but the ditch is not filled in yet. It has worked fine this last week! Until this last rain storm that dropped 3 more inches. My leach field is backed up again. I had to dig the secondary tank up and pump it down so we can shower.
We are leaving for a week in Las Vegas, so it will have some time to return to normal. I say some, because we are slated for 4 more days of rain this week, while we will be gone. We already have 5-6 artesian wells that have sprung up on our property. So at least we will not be adding to it. I noticed the cracks near the access hole appear to have widened. Also a chunk from the access lid broke off as well. I am about sick at this point.
When I get back, I will at least look into getting a new top set in place. I am sure it will be in the thousands. I am not confident the neighbors Case 680 will handle it, and I don't want another one broken, so I will have to have a excavator set it, most likely.
Now for the real fun, this past Saturday, about 330pm one of our healthiest valley oak trees (remember we have this rain coming after a 5yr hard drought) that was about 50ft tall, just fell over. The root ball is about 7-8ft high, and our little 20" chain saws cannot separate the trunk from the root ball. It is over 4ft wide at that point. The tree was right beside our main dirt road, and uprooted part of the road. We were about out of propane and the driver refused to drive through the muck. I cant blame him either. My wife came up with getting access from our neighbor going through his gate and coming to our tank from the back way. So at least we got that.
One of the neighbor's sons is gonna start hauling in about 20 tons of gravel tomorrow and I will try to spread it. Our road is almost impassable at this point. Water is coming, through hydraulic pressure, is coming out of the side of one neighbors hillside, and is flooding our road and making it the consistency of wet mortar.
So, the fun continues!
Our NORMAL average annual rainfall in this area is 17". We usually get that rain from about Oct, through March. We got very little rain, until January, and have gotten over 32" in ONE MONTH, and 4 more days of it coming. I am tired of rain!
LINDE H80D FORKLIFT (A58216)
LINDE H80D...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2019 MACK PINNACLE (A58214)
2019 MACK PINNACLE...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
Sprayer Specialties XLRD 1250 Sprayer (A59814)
Sprayer...
