Root Rake/ Grapple combo
   / Root Rake/ Grapple combo #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
This is similar to what I started with. A hitch assembly, and 9 box blade ripper shanks.
Fiinished product.
This all took a bit of welding, and fitting the hydraulics cyl to work properly . Cost , hitch $40.00, Shanks $15.00 each, 4 inch 1/2 inch steel, free. Used a Lincoln 175 mig. About 20 hours rounding up the parts and welding.
Hardest part was drilling out the end hole in 4 of the shanks for 3/4 grade 8 bolts. That is some some hard steel. Wore out 4, 3/4 bits. I had to torch out the holes, and ream with 3/4 carbide reamer.
Every thing turned out according to plan.
It will not grab a large bite, but the 3/4 steel shanks will handle all my tough stuff.
Grapple closed.
   / Root Rake/ Grapple combo #5
J.J.
Very impressive. Your work is on the scale of a professional manafactory plant.
Thanks for sharing your talents.
PJ
   / Root Rake/ Grapple combo #6
Good job, JJ!! I need some kind of grapple arrangement for moving cut brush to the bonfire, that looks like it might just do the trick. Got a MIG welder for Christmas but haven't had anything to weld yet... this'd be a good project. AND I already have the hitch, so I'm $40 ahead already.
Thanks for the idea and photos.
Phil
   / Root Rake/ Grapple combo #7
I'm curious J.J., why did you use a hitch instead of some square tube? Was it because of availability?
   / Root Rake/ Grapple combo #8
Real nice looking grapple JJ .... looks like it will work well for a lot of stuff and the price was right.
I had several of these laying around, and the price of steel seems to go up every day. Steel tubing would have worked.
It just worked out well for a small sturdy grapple/root rake.
   / Root Rake/ Grapple combo #10
Very nice! /forums/images/graemlins/laugh.gif
   / Root Rake/ Grapple combo #11
Nice!
Looks aggressive!
   / Root Rake/ Grapple combo #12
J.J. you keep tickling my grapple bone /forums/images/graemlins/tongue.gif
It looks great! A very simple design, nice work /forums/images/graemlins/laugh.gif
Where did you buy the shanks?
I was looking around on the net last night to find them with no luck.
I purchased some of the shanks at a tractor place that sells new and used tractors of many brands. They sell lot of implements also. I was looking at their grapple rakes, and they seem high with the price of steel. As I walked by the box blades, I took one look at the shanks and came up with the idea of my grapple/root rake. These shanks are 3/4 thick and very hard steel. I purchased some of them at the tractor place, and some of them at TSC. The ones I got from the tractor place were three hole shanks at $15.00 each. The top shanks have four holes and are a little longer. TSC had them for $29.00. so I asked them if they would match the price of the other tractor place, and they did.
Anybody that sells box blades, should have them in stock, or can order them. One of the tractor places wanted $50.00 for one, and I just thanked him and kept on looking
Another option, I drew up a design of a grapple fork on one of my Cad progams, and had a steel fabricator cut it out on their cnc machine. A single 1/2 inch shank cost me $30.00.
I would try and get the shanks locally, because the shipping would be rather steep.
   / Root Rake/ Grapple combo #14
I will look around. There are several fabricators around here that make landscaping and farm implements. (New Holland, the land of tractors...)
I'll also check with TSC too. There are three stores within driving distance.
Looks like I'm going to have to load Autocad back on my computer again!
   / Root Rake/ Grapple combo #15
Fine Job JJ. Its looks like it would be better that the PT grapple bucket for moving several logs at once or piles of brush.
That is a very good price if the shipping is reasonable. I would suggest looking at one before you order on line to see if the curve is what you want. Those shanks are heat treated, and that makes them hard to drill out the holes, which are only 5/8 in. I cut mine out to 3/4 in and used grade 8 bolts and lock nuts. Good Luck.
Did you mean to write 18 in shanks?
   / Root Rake/ Grapple combo #19
</font><font color="blue" class="small">( Did you mean to write 18 in shanks? )</font>
Busted.... /forums/images/graemlins/blush.gif
Yes, 18" shanks.... dang you!! /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif
Here is another example for the ripper shanks. This guy hauls logs with his.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2023 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A60429)
2023 CATERPILLAR...
