Root grubbing with my GC1705
   / Root grubbing with my GC1705 #1
Jimc295
Cleveland GA
Massey GC1705, Kubota B7100
I'm learning to clear out small saplings and vines and small tree stumps. About the biggest I've successfully tackled is in the 3-4 inch range anything larger I really have to abuse the tractor. I cleared about a 35-40 x 15 foot bank Saturday. It is all trial and error for me because it is my 1st loader. I found that I can raise the blade and bump the stump to loosen and then go low and use the curl function to pull it out. Any tips would be appreciated.
   / Root grubbing with my GC1705 #2
I usually cut the tree with about 12" to 18" high stump, and under 6" diameter I just scoop up with the front end loader bucket.
6" to 12" I usually let it sit for a year or two, and choke the stump with a chain and gentle tug on the stump.
12" to 24" I usually use the backhoe, and I've had some tough Tamarack stumps that do not want to be removed at all.
Good luck, KC
   / Root grubbing with my GC1705 #3
Stick it low and curl the bucket up, that is where the power is and that is how I got this rock out, the only reason I knew the rock was there is that I hit it with the teeth on my box blade, took two tries to get it out and it did not even mark the Piranha bar.
   / Root grubbing with my GC1705 #4
I forgot you had seen this ^^^^^^^^^^ on my other post.
They say the mind is the first thing to go hahaha.
Charlotte County (A50323)
Charlotte County...
7046 (A50322)
7046 (A50322)
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52748)
Ditch Witch 6510A...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2016 KOMATSU D61PXI-23 CRAWLER DOZER (A51246)
2016 KOMATSU...
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
