Root balls on downed trees.
/ Root balls on downed trees. #2
Interesting Mace........if that tree stays up for 4 hours......he should call a tree doctor!:laughing:
/ Root balls on downed trees. #4
Cool video, I'm wondering if the back and fourth motion with his new Stihl could have gotten the tree a bit excited :shocked:
/ Root balls on downed trees. #5
Someone else also posted this. Clearly an inexperienced sawer.
When dealing with a downed tree, always cut the football off first. And make sure the hole is clear. Watch the saw kerf. Cause it is hard to tell if the top will be under tension(roots wanting to settle back to hole), or compression. So watch the kerf. If it starts to open up, you know is going to drop back into the hole. If it starts to close, it is wanting to topple on over away from the hole. And if it does neither, don't leave the ball standing on its own. Get the reactor and push it over.
/ Root balls on downed trees. #6
I had a HUGE oak root ball jump back into the hole once. It was much much faster than this video. Even if you know it is going to happen it can be scary.
/ Root balls on downed trees. #7
I guess I am not surprised that someone hacking away with an obviously dull chain would make this mistake! I always prop the rootball with a log or timber first if at all possible. Cutting on a tree with a detached rootball is no different than cutting on a leaner, as they can barber-chair in an instant and knock your block off. I'd use a specialty cut to avoid barber-chairs (I like Coos-bay variations).
/ Root balls on downed trees. #8
I like to cut the tree down even though it's laying side ways.
Box and back cut, the tree only "falls" a foot, but the sway of the root ball makes up for the excitement.
/ Root balls on downed trees. #10
I have a friend that was cutting large oak trees on his place that were uprooted by a tornado. He didn't realize his two sons, (age 6 & 7) were playing in the hole when he cut the trunk. They didn't find find the kids for hours.
/ Root balls on downed trees. #11
That's awful, I couldn't imagine...
I have always wondered if it would make more sense to break up the root ball first. If it fall back in the hole, doesn't that make it harder to deal with the stump?
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
