Rookie with Hydraulic Snowblade on 318 has a ?
   / Rookie with Hydraulic Snowblade on 318 has a ? #1
abigpicture
Just hooked up the blade today to check out its operation. Works fine angling but intermittent on the up/down. I then diconnected the up /down hoses and now I cannot get one hose to connect properly. Is it because the cylinder is under load? advice please the blade is in the up positon off the ground right now? <font color="green"> </font> <font color="green"> </font>
Thanks
ROokie with hydraulics.. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif <font color="green"> </font>
   / Rookie with Hydraulic Snowblade on 318 has a ? #2
Welcome to the forum.
Wrap the hose tip with a rag, and carefully press on the ball in the end of the male fitting. Oil will come out when the spring pressure behind the ball is exceeded. Protect your eyes and clothes. That will relieve the pressure.
Check that you have the hoses connected to the right lift and angle levers. Usually the intermittent is on the angle side, and is caused by a valve not closed (it shuts off the oil going to the deck lift cylinder, if I remember correctly). Look in the manual for that fitting and that condition.
   / Rookie with Hydraulic Snowblade on 318 has a ? #3
And - turn the tractor off and wiggle the levers back and forth to relieve any pressure on the tractor side.
works good now..thanks all /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
1768 (A58375)
1768 (A58375)
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2015 John Deere 550 S4 (A57149)
2015 John Deere...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
1999 Peterbilt 379 Tandem Axle Road Tractor (A55272)
1999 Peterbilt 379...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
