Rookie with Hydraulic Snowblade on 318 has a ?
   / Rookie with Hydraulic Snowblade on 318 has a ? #1
abigpicture
Just hooked up the blade today to check out its operation. Works fine angling but intermittent on the up/down. I then diconnected the up /down hoses and now I cannot get one hose to connect properly. Is it because the cylinder is under load? advice please the blade is in the up positon off the ground right now? <font color="green"> </font> <font color="green"> </font>
ROokie with hydraulics.. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif <font color="green"> </font>
   / Rookie with Hydraulic Snowblade on 318 has a ? #2
Welcome to the forum.
Wrap the hose tip with a rag, and carefully press on the ball in the end of the male fitting. Oil will come out when the spring pressure behind the ball is exceeded. Protect your eyes and clothes. That will relieve the pressure.
Check that you have the hoses connected to the right lift and angle levers. Usually the intermittent is on the angle side, and is caused by a valve not closed (it shuts off the oil going to the deck lift cylinder, if I remember correctly). Look in the manual for that fitting and that condition.
   / Rookie with Hydraulic Snowblade on 318 has a ? #3
And - turn the tractor off and wiggle the levers back and forth to relieve any pressure on the tractor side.
works good now..thanks all /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
INGERSOLL RAND G80 GENERATOR (A52472)
INGERSOLL RAND G80...
