Rookie question
   / Rookie question #1
PaulieD
Upstate NY (Adirondacks)
New Holland Boomer 35
Last weekend I decided to attend to the 50hr service on my TC-30, 7308, and rotory mower. I think I found all the zerks and checked the oil levels for the gear boxes, but I ran out of time and didn't change the oil/filter or the gas filter. My question is this: I don't have a tool for removing the oil filter, do I need one or can I remove the filter by hand or with a general purpose tool.
Thanks, Paul
   / Rookie question #2
Strap wrench at sears
Jim
   / Rookie question #3
As the above said the strap wrench.I try to use the regular filter wrench, or some large pliers. It all depends on how much room there is and how tight the filter is.
And remember to coat the new seal with oil or grease. it will seal it better, and make future removal easier.
Al
   / Rookie question #4
regular filter wrench of any configuration works jus' fine. I used to write the hours and date on my filter whenever I changed it so it was close at hand and whenever I checked the oil - there was the date I changed it last looking at me. THEN they changed the color of the filter! used to be white - now is black ......the last time - when I opened the box to take the filter out - I actually laughed out loud at the joke on me.:D
   / Rookie question #5
Could you use a fine tip white or silver marker for writing on the black filter?
Guy.
   / Rookie question #6
yeah, I'l be getting a white one ---- but I had the black perm marker in my hand at the time ....just struck me funny as H ... all set to write, but black on black weren't gonna werk so gud.:D
   / Rookie question #7
Hopefully the same gorilla that put my filter on at the factory did not do yours. Mine was REALLY on tight and due to the FEL frame was also difficult to get leverage on. I was not able to use a strap wrench, so I picked up the plier type filter wrench from Napa and it worked great. The filter bracket on my TN also wanted to turn so I had additional opportunities there :)
General purpose tool = screwdriver thru the filter and turn by hand, but this gets a little messy
You probably already know this but when changing the fuel filter you will probably need to prime the fuel pump afterwards
   / Rookie question #8
I second the oil filter pliers. I tried everything else with no luck. Greg
   / Rookie question
Thanks for all the help and advice.
I'm a part time lurker on this bulletin board. I don't know enough, or have enough experience, to offer any advice. So I just read through the threads and learn from all the experienced participants. Thanks for help with this question, and all the other advice you've unknowingly provided me.
Paul
   / Rookie question #10
I bought a very wide strap wrench at the Case IH dealer. 3 inch width for the strap. wORKS GREAT.
bOB
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
